Results 1 to 9 of 9
Thread: {Transmission} AOD high speed govenor how to
    Birdsboro PA.
    17,391
    Default {Transmission} AOD high speed govenor how to
    ok many of us have modified 302 ho's in our cars.....much need for a higher shift point. installing a high speed govenor from a mustang is reall easy.....heres how. sorry no pictures yet, my camera is broke
    1 remove driveshaft (4 bolts, they are a 12mm 12 point)
    2 remove speedo cable/speed sensor (11mm wrench)
    3 put a jack under the pan and unbolt the trans mount (4 11/16 bolts)
    4 remove the 6 tailshaft bolts (13mm socket)
    5 carefully remove the tailshaft......you may need a new gasket if it tore
    6 remove old govenor (2 bolts with phillips heads)
    7 install mustang high speed govenor
    8 reinstall, add 1/2 qt tranny fluid and check for leaks
    9 enjoy!
    the govenor cost me $11 from the ford dealer
    scott
    Nov 1982
    Wetumpka, AL
    20,424
    What about the snapring??
    My screen name is GREEN, Bitches ! 88grandmarq's Avatar
    North Georgia
    2,194
    Tom... there is NO snap ring
    Nov 1982
    Wetumpka, AL
    20,424
    Cool, so I coulda done it easily...
    Thanks STfU..he told me differently...
    Birdsboro PA.
    17,391
    friggin eric takes pictures of everything hehe good job eric!
    Nov 1982
    Wetumpka, AL
    20,424
    Of corse, if your hands are that damn big, anything looks small!
    Photobucket Paul_'s Avatar
    Milton, NH
    9,234
    would installing that governor serve any purpose on a non-HO Vic? mine eventually will be HO but not at the current moment.
    Save a seal, club a liberal.
    North Georgia
    2,194
    Not really, since the stock cam makes power to 4200 RPM. Once you do a HO conversion, then you want the higher shift speeds, because the HO cam makes power up 4800 rpm.
    A shift kit and a "A" O/D servo would greatly help the stock trans.
    Member NitroNic's Avatar
    OK, USA
    258
    Default Re: an aod high speed govenor how to
    Quote Originally Posted by lincolnmania
    Is it just me, or would it be a good idea to put like a board of wood between the jack and the pan? I didn't think the pan was really made to hold the weight of the transmission.. .I"d think it would collapse in the middle.
