ok many of us have modified 302 ho's in our cars.....much need for a higher shift point. installing a high speed govenor from a mustang is reall easy.....heres how. sorry no pictures yet, my camera is broke
1 remove driveshaft (4 bolts, they are a 12mm 12 point)
2 remove speedo cable/speed sensor (11mm wrench)
3 put a jack under the pan and unbolt the trans mount (4 11/16 bolts)
4 remove the 6 tailshaft bolts (13mm socket)
5 carefully remove the tailshaft......you may need a new gasket if it tore
6 remove old govenor (2 bolts with phillips heads)
7 install mustang high speed govenor
8 reinstall, add 1/2 qt tranny fluid and check for leaks
9 enjoy!
the govenor cost me $11 from the ford dealer
scott
9 enjoy!
scott
