Page 14 of 14 FirstFirst ... 4121314
Results 261 to 267 of 267
Thread: 1982 Mercury Marquis
  1. #261
    Mar 2013
    New Haven, Indiana
    1,254
    I doubt it should. I’m sure the mechanism is the same, the difference probably just being a crank handle vs an electric motor to move the glass.
    That's exactly what I was thinking. Hopefully it's that simple.
  2. #262
    Mar 2013
    New Haven, Indiana
    1,254
ID:	52669Click image for larger version.
ID:	52671Click image for larger version.
    Finally got the 96 acke stripped, primed and painted!!! After such a loooooong process I finally got all the parts and we are ready for reassembly!
  3. #263
    Nov 2006
    Dirty Jersey Yo!
    7,947
    Nice!!!
    If I had waited a couple years, I could have gotten a '94 rear from the JY I frequent. At some point, I will break down and want rear discs on the CV
  4. #264
    Mar 2013
    New Haven, Indiana
    1,254
    Nice!!!
    I wasnt gonna do it. I was just gonna do gears in my stock axle. But I said to myself, itll never be what I want if I dont do it now... here we are a year later... but it will actually be what I want.
    That and I would also have discovered eventially that my 8.5 would have to be removed anyway haha
  5. #265
    Mar 2013
    New Haven, Indiana
    1,254
    its finisssssshhhhhhhed... finally. took damn near 2 years. but i now have 3.73 traclok with disk brakes it was fully stripped down painted and rebuilt, every bearing and seal replaced, complete gear swap and brake rebuild.
ID:	53789Click image for larger version.
    also learned some new things along the way and adjusted my shopping list accordingly. Back in the fall, i picked up a 2003 PI. it was supposed to be a decent driver, but i ended up stripping it and i never plated or even drove it... fast foward to now.. i salvaged the driveshaft from it, and its going in the 82. I had a bunch of conflicting info but after some side by side i finally figured it out.. in my particular application (others may differ) i am gonna be using an 03 aluminum driveshaft bolting to the 96 axle, no issue. Ill need to swap the yoke and i already knew this because i going to a T5, but i didnt realize id be able to use my stock one. yay! i was also anticipating length differences but they are all spot on so i dont think ill be needing a spacer either. anywho.. im sure most people who have done this swap already know all the info im sharing, but pictures always help. so heres a comparison between them. One from my 82 with 8.5 rear, the other steel with the chopped off end from an 88 Marquis with 8.8, and then the aluminum one from an 03 Crown PI with 8.8.
ID:	53791Click image for larger version.
ID:	53792Click image for larger version.
  6. #266
    Fort Wayne IN
    5,616
    Nice! I have a 3:27 disc rear in the back of the 82 I just bolted in. I have the same steps to take to finish like you.
  7. #267
    Mar 2013
    New Haven, Indiana
    1,254
    Quote Originally Posted by p71towny View Post
    its done now. and i absolutely love it. wayyy more pull on takeoff, even with the garbage 255. only issue i have, is that the box sway bar is hitting the sway bar mounts on the 96 axle since its a different style. ill chop those off and should be finished.
