Last week my trunk would not open. I had to remove my rear seat and luckily the plastic shroud that covers the pull down motor was not in place. The three bolts that hold the trunk motor were exposed so I initially tried to reach my arm through the rear seat with a ratchet on a long pole but the nut was barely spinning. I was loaned a nice device called a sidewinder to get on a 90 degree angle for the bolts. I got the trunk motor unbolted from the body within 5 minutes. If this had occured without the shroud off, I would have been taking a sawzall to the trunk lid. Long story short. It appears as though the rivets that held the actuator in place came loose and the actuator fell out. It doesn't sound like it's operating anymore either. Are these available? It only has 1 wire going to it does that sound right?
87 Town Car trunk actuator. Trunk not opening.
87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
Mods to come: Big Brake/Poly Front Swap, PI Front Swaybar, Addco 650 Rear Swaybar, Boxed Upper Rear Control Arms, 351/Alum Heads, FRPP Valve Covers,Tags: None
One wire is possible, although I am not familiar with that actuator.
The one wire must be a positive (12V) line and it must ground through case/mount to the body. If the actuator is loose that may be why it is not working because it is not being grounded properly. If that is the case you may not need a replacement, but again I am not familiar with that particular actuator and how it is setup.Vic
Absolutely correct VicCrownVic. You're right. It's grounded through the bolt and body. When it loosened and fell out , it was no longer actuating! Thanks buddy. Problem solved.87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
Awesome, now I'll have to check my 91 MGM has the same issue. My actuator stopped working a few months ago but since I can still get in with the key I've been too lazy to investigate the issue.Vic
Hmm. Yeah. I wonder why I couldn't get in with the key still? I'll have to check that out..87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
Originally posted by 87stars_stripes View PostHmm. Yeah. I wonder why I couldn't get in with the key still? I'll have to check that out..
Look the latch/lock mechanism over for anything that looks like it's binding and make sure it's all lubed.Last edited by VicCrownVic; 06-05-2014, 10:24 PM.Vic
