2004 mercury grand marquis
Results 1 to 2 of 2
Thread: 2004 mercury grand marquis
    Default 2004 mercury grand marquis
    Can someone direct me to a good wright up on dash removeal? I got most of it loose, but I must be missing a fastener o. The right side. Does the metal frame need to be removed under the dash?
    I have to change out the heater door actuator.
    Any info will be helpful.
    Thanks.
    Nov 2012
    Shelby Township, MI
    3,799
    If it's anything like the 90-94 MGM take the glove box out and look just inside that cavity on the left and you may find a couple bolts holding a brace in place.
