Scott and guys maybe you can help. Mu 1990 CV will not start, it started last night after I got gas I got in my car and turned the Ignition and the sound of death to the Starter Solonoid and I called AAA to get me started, so a jump start was unsuccessful and I installed a new Battery still no start, so the AAA tech whacked the Starter Solonoid and my car started and that lead me to beleave that I had a bad one. I installed a new one still no start the sound of death to the solenoid. I it will not cost me a small fortune to fix so help me out if you can. Thanks in advance for all of the suggestions.
No start.
What type of new solenoid did you install? I know there are bad ones fresh out of the box....had this issue with my Lincoln, it was a new, white in color solenoid (forget the brand) and was bad right out of the box.
Did you try bridging the two posts on the solenoid with a screwdriver? If it starts, then the solenoid is bad.
As Louis sad, jump the stater solenoid, if it starts, it's bad. If it doesn't, you have other issues.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
pull the cables off the solenoid and wire brush them. Sounds like a bad connection there, or the + cable is shot. A 1990 should have the later style starter if I'm not mistaken. Those solenoids are under very little load and rarely go bad with that style starter. They will develop bad connections after a while though, and the battery cables will corrode internally too.86 Lincoln Town Car (Galactica).
Yep, 1990 should have the newer style starter and if it is the original from the factory starter, like on my 91 MGM before I replaced it, the thin ground wire to the starter tends to corrode.
http://econtent.autozone.com:24999/z...tbfordpmgr.pdf
^That information came with a new my new starter.Vic
90's won't necessarily have the new style starter. My '90 has the old school starter on it.1990 MGM: $50 E7 heads, HO cam, Holley SysteMAX lower intake, HO upper intake with an Explorer TB. LSC ECM. Lincoln logs into stock dual exhaust. K&N drop in air filter. Wide ratio AOD, 2400 converter with a 3.08 one tire fire out back. Car is less slow now. Then there's the '92 Beater. Dual 2.25" exhaust with shiny tips. Rumbles nice. Super slow. Burns oil too.
Originally posted by HiFiMerc View Post90's won't necessarily have the new style starter. My '90 has the old school starter on it.Vic
Originally posted by VicCrownVic View PostInteresting, I wonder when they switched to the new starter, I assumed it was 90+ all had the new starter.
The fender solenoid went bad on my old 91, which had the newer style starter, so I wouldn't instantly rule it out.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Don't forget that Ford recalled tons of ignition switches on these cars and trucks. I had everyone of my CVPIs changed out by Ford during the recalls. I also have had several aftermarket switches go bad on other Fords, and have to be replaced them a second time. The switch is located in the column and requires a T-27 anti-tamper bit IIRC.
Guys thanks for the advice and your help, so what killed my car was a bad negative battery cable. Now I gotta deal with a intermittent "check engine" light and yes my PCV and filter have been changed, so I THINK I may have an EGR valve plugged up. I am gonna try and borrow a scan tool to see the Code UUUUUGGGG!
You can just do the engine running diagnostic test instead getting a scan tool, I may be wrong here but I think it will show you the same codes. And hell, all you need is a paperclip.Current cars:
1989 Crown Victoria LTD wagon, 94,872 miles
1990 Volvo 240 DL 318,513 miles
I've tried foreign cars but I always come back to Ford in the end.
