Hi all,
I'd like to do the disc/posi swap for my '88 (Got stuck backing in my driveway for the last time!!) but it seems more complicated than the swap I did with the Firebird, which was aquire a posi unit with discs from an '83 pacecar T/A & bolt up and connect the rubber hose to the T on the diff.
I read through this:
http://www.grandmarq.net/vb/showthre...Disc-Rear-Swap
And it caused me to be uneasy & reconsider the swap, perhaps I should just pay to have a posi swapped in my current rear end and deal with the drummies? I don't relish the idea of having to swap over the master, worry about the proporting valve & booster although my biggest concern is with the e brake & rear lines, a dude mentioned having to flare the lines to match but another said he swapped just the rear over & all was well (John I think?) Anyway, the shop that swapped the Firebird's axle quoted me at $610 to swap in a new trak lok & $350 to swap an axle over. I ended up paying close to $800 though with the bird because I had the axle stripped, painted and they replaced a few bearings inside.
What say you guys? Am I overthinking the problem? Should I just swap the non posi carrier for one that is? Are disc brakes that much better back there or can similar stopping power be had with the later MC & booster? Disc rears on the bird made a huge difference...
I'm not sure how to go so your thoughts and comments would be appreciated!
Derek
Derek
