I want to jump ship but hear as much negative about efans as I do positive.
Monty's 1989 CV LX
If you loosen those fan bolts before removing the belt and use some penetrating oil, they come out without any particular fuss. I don't see what the big deal is.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostIf you loosen those fan bolts before removing the belt and use some penetrating oil, they come out without any particular fuss. I don't see what the big deal is.
I tried removing those bolts with the belt off once only to figure out that it wasn't going to happen, so I put the belt back on and had no problem getting the bolts out.Vic
Backs the issue. Bending over for that kills the back and my legs from stretching. How often is one removing this stuff anyways....no pain no game.~David~
Originally posted by 87gtVIC View PostBacks the issue. Bending over for that kills the back and my legs from stretching.
I can't get a socket on them f'n bolts, can't turn them very much for shit until they get out a full 3-5 threads... they're not that hard at that point, but it takes 20-30 minutes to get the f'n things out and I can have an e-fan out and replaced in 15 WITHOUT my back bitching for the next 2 days from being hunched over for an hour.
Which gets back to my point, a clutch fan you don't have to dick with often enough for that to be a concern.86 Lincoln Town Car (Galactica).
Originally posted by sly View PostFan bolts... the reason I want e-fans.Originally posted by 87gtVIC View PostBacks the issue. Bending over for that kills the back and my legs from stretching. How often is one removing this stuff anyways....no pain no game.1985 LTD Crown Victoria - SOLD
Originally posted by gadget73 View PostWhich gets back to my point, a clutch fan you don't have to dick with often enough for that to be a concern.
yeah screw that.86 Lincoln Town Car (Galactica).
3 of those are easy, shallow holes with access to the back. Heat them up with a propane torch and they should come right loose. Can't see where the other one is. If its one of the long ones into the water jacket, the timing cover comes off. That makes getting the 3 top ones out even easier.86 Lincoln Town Car (Galactica).
Time for a new cover. Or some handy easy out work.
I broke a bunch of shit, gotta keep movin on. Life is just an un-ending story of disappointment.__________________________________________________
