Page 1 of 5 123 ... LastLast
Results 1 to 20 of 91
Thread: Need more help...
    Default Need more help...
    Car ran fine night before, get in today needed gas so I went out of fill it up, started having a dead miss every once and while under throttle so I filled it up with 93 like I usually do and it kept doing worse and worse, floored it up the road see if maybe just needed to be cleared out and it got worse to the point where it barley idles now and won't run at all
    IMG_3204.MP4
    Nov 2012
    Shelby Township, MI
    2,349
    Check the fuel pressure.
    If it's EFI (in tank fuel pump) the hose inside the tank between the pump and tank output may have split and most of the fuel will then dump right back into the tank. Has the fuel filter been changed recently?
    Edit: '87, 302 should be EFI.
    Gone but not forgotten:
    35,663
    Ah, you filled it up. Definitely a fuel pump then. They only die when its most frustrating to change you know.
    Not kidding all that much, though I'm sure its coincidence. Check the fuel pressure, go from there. Fuel or fire, but this definitely sounds like fuel to me.
    Mar 2007
    North Las Vegas Nevada
    2,118
    If you can check fuel pressure if below 36 psi need new pump.
    Anything below 36 is bad?
    Nov 2012
    Shelby Township, MI
    2,349
    I'm not at home w/service manual but I think 36 is in the good range. We're you able to get a reading?
    Do you hear the fuel pump run when you turn the key on but don't crank the engine? It should prime when you do that. If you don't hear it, it's likely a dead pump based on the slow death. A relay is either on or off, so it doesn't seem to be the fuel pump relay.
    If you do hear the pump it could be the in tank hose, or the pump going/gone weak, or even a clogged filter.
    This is what I got, barley idleing
    So does that mean it's the pump in the tank?
    35,663
    32 with vacuum connected to the regulator, 42 without is the norm. 25 is too low. The regulators very rarely fail, but if you pull the vacuum line off and it has gas coming out of the reg, there's your trouble. regulator is on the fuel rail, and has a vacuum line going to it.
    Fair chance its the pump, but try changing the fuel filter first. You might get lucky.
    Mar 2007
    2,118
    If the fuel pump reads below 36 PSI chances you will need a fuel pump my car the fuel pump went south car idled fine but no go fast it measured below 36 PSI so I had it replaced now my car runs fine.
    88 LTC nfldfordltd's Avatar
    Oct 2005
    Happy Valley-Goose Bay, Newfoundland and Labrador, Canada
    843
    It could be the pump unit fell apart inside the tank. My 88 Town Car did exactly what your car is doing now a couple of years ago. Turns out the pickup tube was almost fell off the pump, so it wasn't building up pressure even though the pump itself was working fine. I tried everything to avoid dropping the tank and removing the pump, but int he end I ended up having to do the big job.
    Summer car-> 1988 Lincoln Town Car, triple blue, 267,xxx km. Out for 2017, new HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
    Winter vehicle-> 1996 Ford F-150 XL 4x4, orange, 302,xxx+km. AKA "King Billy". Takes the beating like no vehicle should ever have to. Bought 2013/11/26.
    19,847
    I've had experience with fuel pressure at 20psi with a water logged fuel filter. Replaced and fuel pressure went back to normal. It can damn well be just the fuel filter after getting some shite gas.
    New fuel pump and tank, same thing, gonna try a new filter tomorrow
    Sep 2014
    Warren, MI
    4,578
    Learn from Karl Childers; Simple things first!
    Yeah yeah, tank leaked like a civ so figured it'd be easier and do both at that same time
    New fuel filter no difference? No idea what else to do
    Car idles okay little rough but any throttle it won't rev up and starts popping
    Sep 2014
    Warren, MI
    4,578
    Hmm, I guess I'd verify your timing. Once upon a time I once changed out a TFI module but the distributor ended up retarded by a tooth. Idled OK but would not rev up and had no power. Chooched lots of white smoke out the back too, steam like. Once corrected it was back to running like a top.
    Sent with my phonic while eating biscuits & mustard with French-fried taters mm-hmm.
    35,663
    Have you confirmed the fuel pressure now with a new pump?
