1986 town car struggling to idle.
    My 1986 town car come with one issue it likes to die when you first get it started up, but once you get it going it’s fine. It’s an odd crap shoot.
    But when it’s finally idling it’s steady at 800rpm, but if it’s struggling and you try to move the car it dies.
    So what do I need to look for?
    I cleaned out the Idle control valve And that did barely anything. It’s weird that once you get it going it’s fine.
    So if it’s warmed up or not has no effect? So what could cause this.
    Engine Coolant Temperature (ECT) sensor is a likely culprit.
    Also the Air Charge Temperature (ACT, also referred to as the Intake Air Temperature (IAT)) sensor could be at fault.
    ECT is on the front passenger side of the engine where the hose that runs back to the heater core is connected.
    ACT is on the front driver side of the lower intake.
    Those two sensors, in that order, is where I would start.
      do you have another known-working IAC? if the sensors are good, it could just be the IAC is bad.
      Is the SPOUT connector missing? That has a lot to do with idle control too.
        ACT and ECT sensors are a good start, and cheap enough it doesn't hurt to throw them at it anyway. Vacuum leaks is always the first place i go though.
          I bought an obd1 Ford Code reader from amazon and it gave me some codes.
          The First one was 63 c which is TPS below voltage which I swapped out the one from the town car with the 86 Vic. Now the car isn’t dying instantly! Hurray!
          The other codes I got were
          12R and 21R
          Which means idle too high and ECT sensor failure.
          The code reader was worth every penny. With my concussion not having to deal with Morse code paper clip stuff makes my life easy.
            Regarding the ECT one, was the car fully warmed up before doing the test?
              Yes, and I replaced the ECT and the idle is now normal.
                good deal.
                12 doesn't actually mean the idle is high. It means it couldn't be raised enough to satisfy the test.
                  Ah maybe I misread the code book either way the car runs great and is absurdly silent with the new tires.
