So on my town car the chip I had burned custom for it shut off my evap system allowing me to gut all that shit. My 2010 Vic has an evap code and I'd like to just disable all that shit and gut it from my car as well. Will a tuner allow me to do that? I've searched to no avail.
Can I use a tuner to shut off my evap shit?
Nope. That was killed a few years back when SCT got sued by the government. They're currently hounding HP tuners for the same thing, but HP Tuners has bigger pockets and apparently better lawyers, so it's dragging on longer. You might contact Adam at Core Tuning www.coretuning.net and see if they can help. Doubtful as they don't list 2007+ models as tuneable. Only up to 2006. You may be stuck with fixing it.
Originally posted by sly View PostNope. That was killed a few years back when SCT got sued by the government. They're currently hounding HP tuners for the same thing, but HP Tuners has bigger pockets and apparently better lawyers, so it's dragging on longer. You might contact Adam at Core Tuning www.coretuning.net and see if they can help. Doubtful as they don't list 2007+ models as tuneable. Only up to 2006. You may be stuck with fixing it.
Originally posted by sly View PostNope. That was killed a few years back when SCT got sued by the government. They're currently hounding HP tuners for the same thing, but HP Tuners has bigger pockets and apparently better lawyers, so it's dragging on longer. You might contact Adam at Core Tuning www.coretuning.net and see if they can help. Doubtful as they don't list 2007+ models as tuneable. Only up to 2006. You may be stuck with fixing it.Chris - A 20th Century Man \m/ ^.^ \m/
or just fix the evap shit. Probably a cracked hose someplace. Need to smoke test it. I think that generation has the box of bullshit right on the bottom of the trunk pan, probably where the issue is. If someone bottomed it out, it may have gotten a rapid unscheduled removal performed.86 Lincoln Town Car (Galactica).
Originally posted by Mr Bean View PostIsn't there a disclaimer that all the tuners have stating that their products are for offroad use only which would avoid the whole emissions thing?
Originally posted by gadget73 View Postor just fix the evap shit. Probably a cracked hose someplace. Need to smoke test it. I think that generation has the box of bullshit right on the bottom of the trunk pan, probably where the issue is. If someone bottomed it out, it may have gotten a rapid unscheduled removal performed.Chris - A 20th Century Man \m/ ^.^ \m/
2010 Vic mentioned in the OP.
