I wanted to add some power without a tune. Duel exhaust and a Tb spacer?
2011 grand marquis lil faster
Dual exhaust, yes.
TB Spacer? Probably won’t see any returns worthwhile.
You can adapt a throttle body from an 05-10 mustang v6 (aftermarket 70mm) or a stock one from an 04-10 5.4 3v for a larger throttle body. But you will have to tap holes in the correct locations.
Also gears and a p71 airbox if you dont already have one but you will need a tune due to the larger maf.
You can also add:
-Steeda under drive pullies
-MSD ignition coils
-Jmod
-Aluminum Driveshaft
http://www.grandmarq.net/vb/showthre...THIS-lt-PLEASE!!!!!!
http://www.grandmarq.net/vb/showthre...Rock96Marquis)
03 Mercury Marauder- 63k
Yea, I'd stick with stock ignition on these. No need for "my spark disappeared" coils. If you want color then paint the COPS whatever color you want. For reference I've only replaced one coil so far, and replaced it with another Motorcraft one.
Definitely recommend the J-mod. On the 11's you shouldn't have to drill too many of the holes on the sep. plate. I j-modded my 03 Sport to the moderate settings back in 08 when I got it and at WOT it will still slip the belt on the 1-2 and 2-3 shift. Normal driving isn't neck-snapping but has a subtle bump. Since the wife drives it I didn't want anything crazy so it wouldn't get away in wet conditions.
Grab a factory dual exhaust setup and different rear gears as mentioned. Likely you have 2.73's out back now. Not sure if you can go to a 3.27 w/o a tune but could be worth a look.
Anything to make power beyond that on these cars is going to cost. Long tube headers, shorter gears, etc. Check out ADTR.net for some ideas. Stainless Works makes some nice headers but you're going to have to pay to play at that point.
Don't forget the suspension/brakes when upgrading power. Extra ponies aren't worth anything if you can't stop/control it. The brakes on these cars are adequate at best and the rear suspension setup is, well, meh... I upgraded to CHE upper and lower control arms for the rear axle and man what a difference. Along with PI spec shocks it really made a world of difference. It's much more planted now and I don't have the overwhelming fear that the a**end will swing out when cornering without pushing it too hard. There are other companies out there that make upgraded gear for the backend but for the money I like it. And I got to pick my color of powdercoat for the armsThese are highly engineered precision vehicles, the first step in diagnosing the problem is to strike the suspected offending part sharply and repeatedly with a blunt object, then re-test.
Where did you order the pullies from? If it was ADTR then shoot Chris an email or call them and they should be able to help out.These are highly engineered precision vehicles, the first step in diagnosing the problem is to strike the suspected offending part sharply and repeatedly with a blunt object, then re-test.
So you got the Steeda pulleys and the ARP balancer bolt. Should be good to go. The only words of advice I have is make damn sure you have the keyway on the balancer lined up and engaged with the woodruff key in the crankshaft before you hammer the bolt in. Usually you can push the balancer on a bit by hand and then tap it with a deadblow hammer to be sure it's on the key. Once the balancer is on properly thread the new crank bolt in by HAND until you meet up with the face of the pulley. This will ensure you don't have any cross-threading issues in the crank, because that would suck.These are highly engineered precision vehicles, the first step in diagnosing the problem is to strike the suspected offending part sharply and repeatedly with a blunt object, then re-test.
