Results 1 to 10 of 10
Thread: fuel tank leaking
  1. #1
    Default fuel tank leaking
    So my fuel tank leaked all over the place while in storage, so i had to deal with that, and that involved me draining the tank and removing it from the car (since i dont want to deal with it in the spring) I was wondering if there are any tips you guys could give me for re-assembly, I currently have a spectre premium f3 tank ordered, any help would be appreciated, thanks
  2. #2
    38,386
    Longer studs, or unscrew the existing ones as far as you can to make your life easier. Replace the seal at the fill neck, consider a new boot up at the fill door end too. New O-rings under the fuel pump and sending unit plates, and if either of those are questionable, change it while its already out. Flush out the evap vent thing that sits at the top too. It gets gummed up with old fuel and then you get a fuel smell and the tank hissing at you when removing the cap.
  3. #3
    fomoco panthers !
    May 2011
    Bangor,Maine
    2,953
    I have always put a thin piece of rubber strap between the gas tank straps and the tank. It prevents sand, dirt from getting between those areas and putting a pinhole leak in the new tank. When I lived in the Ca. desert, that was a problem with the sand. In the rust belt, salt or the salt brine would be a problem. Just a suggestion.
  4. #4
    Member
    Jul 2013
    Central North Carolina
    332
    Internal rust and rot is common with our Crown Vics. Check the filler neck carefully and make sure it's not rusted through as well (fuel pressure issues could result from a leaky filler neck). Take gadget73's advise! Also don't trust that old filler neck doughnut. Good luck and wear safety goggles when working.
  5. #5
    Member WagonMan's Avatar
    Sep 2004
    Bridgewater Ct.
    512
    I just put a new tank in my 89 Wagon. The lock ring provided with the Spectra fuel tank is junk. Try to use the original if it is in good shape. WagonMan
    1990 Colony Park
    1970 HEMI Superbird
  6. #6
    Member a_d_a_m's Avatar
    Mar 2009
    Cleveland
    362
    It must be the time of year for tanks. I just had to put one in the Squire. Had a friend's lift open for the day, so I used it and his help.
    The Spectra was sold out, so I ordered the Liland Global IF19 at $95.79 + the ride minus 5% from RockAuto.
    Absolute +1 on longer studs - not sure what of each dimension changed but the factory studs do not work. My filler neck donut was fine; couldn't find one local anyway so I reused it. The lock ring provided with the Liland Global tank was a tight fit, but did seal tightly with the provided O-ring gasket.
    '91 LTD Country Squire LX | '04 CVLX ($200 winter beater) | '03 SAP P71 | '03 Marauder
    formerly: '02 MGM, '04 MGM, '04 MGM v2.0, '04 MM, '07 P71 w/5-speed
  7. #7
    Nov 2012
    Shelby Township, MI
    2,974
    Quote Originally Posted by a_d_a_m View Post
    I don't need to replace the tank, but do have a new fuel pump hanger assembly to go in on Saturday since we put a hole in the return tube last week on the 7 year old hanger assembly. (Luckily '90+ non wagons don't require tank dropping.)
    The factory studs were longer at the factory, the nut was put on then the studs were broke off at pre-scored spots leaving the studs short. At least that's the explanation I've heard a few times.
    ~ 1997 GMC Yukon - wannabe winter DD - returning summer 2020, I finally have an engine
    Gone but not forgotten:
  8. #8
    I ended up having to use the new ring, because the old one was in bad condition, hopefully it will be fine.
  9. #9
    Also whats the size for the stud and nut for my 85' (just in case I have to drop the tank again)
  10. #10
    38,386
    something metric I'm sure. M10 or M12 most likely. Nut size would mostly tell you. M10 usually uses a 17mm socket , M12 is 19mm.
