Results 1 to 14 of 14
Thread: Charging issues
    Default Charging issues
    I had my high beams on, radio, heater, and rear defrost, then the battery was charging at 12.9 to 13.5 and then the car died. With nothing on at all it charges at 14-14.2v, I was wondering if I should upgrade to a 100a alternator, or finally do a 3g swap, any ideas would help, thanks
    Nov 2014
    Evans, GA
    1,538
    3G swap and ride. You’ll appreciate the difference.
    18,851
    You should be able to. It comes with decent instructions IIRC. Tells you how to retain choke and whatnot.
    I bought that kit for my father and his 1985 mustang GT (with carburetor) and he has no issues for a couple years now.
    EDIT. You will likely need a bunch more 4 gauge power cable. The kit caters to the fox body which in those years had the alternator on the passengers side right next to the battery.
    thanks, appreciate the help!
    38,503
    The 100a needs a different upper bracket, and doesn't really have much better idle speed output than the 50 or 60a you have now. Honestly no point in using one. The 3g is the better unit.
    I'm cheap though, I'd get just the alternator and deal with the wiring myself. The conversion regulator is literally a box with a jumper in it. There isn't anything special about it. It doesn't even have 2 jumpers so you have a battery reference line direct from the battery.
    I think im going to gather everything I need from the wreckers, and parts store, it seems to be the cheapest option for the 3g swap.
    Nov 2014
    Evans, GA
    1,538
    Quote Originally Posted by 1985crownvicltd85 View Post
    That's not a bad idea. That's how I did mine.
    This is my typical forumla:
    1.) Get any small case 3G, preferably from a '94-'00 V6 Mustang. I just like the voltage regulator plug position on those, but the '94-'99 3.0 OHV Taurus/Sable ones work fine.
    2.) Take the voltage regulator pigtail from the donor car.
    3.) Yank the whole charge cable from a '96-'99 OHV Taurus/Sable (gotta extract it from the main harness on the radiator support).
    4.) Grab the 175 amp mega fuse from the car with the charge cable.
    5.) Purchase a bolt and lock nut (or lock washer and nut combo) that'll fit the top hole so you can tighten the alternator into place.
    Opt. 6) Get a fuse holder for the mega fuse. I've just taken the mega fuse and bolted it together on one end with the charge cable and put the other end directly on the stud coming off the starter solenoid. It's not as pretty, but it's been working for over three years, so YMMV.
    Opt. 7) Get a new belt. You may actually have to get one anyway if the old one doesn't fit. In my case, using a alternator from a '96 V6 Mustang, I needed a K060509 (alternate no. 6PK1295) belt.
    Also, you could substitute ripping the whole charge cable out if you're not feeling up to it by just getting a battery cable at a parts store that's long enough, and then hooking up the fuse.
    Im thinking of buying this: https://www.painlessperformance.com/wc/30831
    and then buying an alternator on rock auto.
    Is there anything else im missing besides the belt, bolt and nut for the alternator?
    38,503
    Taurii? Taureses? whatever the plural is. They have a nice charge cable and fuse that can be robbed. Takes a little time to extract it from all the clips and zip ties but its got the proper end to fit the alternator and its long enough to fit a Panther. There is a 175 amp fuse in there too. You want a fuse holder for it. Not 100% if you can steal that from the Taurus, I don't exactly remember what it looks like but its a common type fuse that a stereo shop ought to have a holder for.
    if you're junkyard shopping. Just a thought.
    Nov 2012
    Shelby Township, MI
    2,988
    The fuse holder is integrated into the under hood fusebox on a Taurtus if I'm not mistaken.
    I found the Taurtus charge to be a little short but am using one on one of the cars with a 1 or 2 (I think 2) foot length of 4 gauge wire between the fuse and fender solenoid. Fuse holder ends up on the front side of the radiator support above the passenger side head lights in my case.
    The 4 gauge wire I bought on ebay meets SAE J-1127 which apparently makes it perfect for this type of application. Here's a link to the wire I bought from the seller that I got mine from: https://www.ebay.com/itm/Lugged-RED-...-/301062820909. The 5/16 end that seller offers should fit the alt and the fuse holder, might need one end with 3/8 to fit the solenoid (I think), but you do have to specify the ends you want otherwise you get one end with 5/16 and the other with 3/8.
    On one of my cars I did not use the Taurtus charge cable, I ordered both the long (alt to fuse holder) and short (fuse holder to solenoid) cables from that seller. I think it was something like 7ft (MAYBE, can't remember and purchase history doesn't go back that far (2017)) and 1 or 2 ft. I would have liked another foot on the long cable though.
    Gone but not forgotten:
    When upgrading to 3g, have any of you added a resistor just in case the warning lamp burns out?
    38,503
    The lamp lasts just shy of eternity. Its only ever on with the key on and the engine not running, or in the event of a failure.
