Results 1 to 13 of 13
Thread: 1.7 Roller Rockers with lopo?
    Auburn Hills Fire Fighter Mr. Land Yacht's Avatar
    Feb 2005
    California
    6,544
    Cool 1.7 Roller Rockers with lopo?
    Has anyone ever done 1.7 roller rockers on a lopo cam?
    I was just wondering this because I'm looking to do basic bolt on modifications to my 89 crown vic that but I'm wondering if having the stock camshaft with 1.7 roller rockers makes any difference whatsoever or if it would be better to swap in the HO camshaft.
    Thoughts?
    -Colin
    Nov 2012
    Shelby Township, MI
    3,205
    A ghost!
    LOL, no idea about the rockers or cam.
    That's not an Aero TC. Is it crystal blue metallic or silver? RR thread?
    Edit: Oh, I see the RR thread now.
    Gone but not forgotten:
    Jan 2007
    Westmont, New Jersey
    10,380
    Quote Originally Posted by Mr. Land Yacht View Post
    Thoughts?
    -Colin
    There was 1 lopo that I know of that had 1.7 rockers. That was the boulevard cruiser (89 colony park). It ran great. Also had HO intake, and stock mustang shorty headers and an exhaust. If you change the cam, you will need to change the computer and at least the heads. And then you'd basically have an 86 mustang HO.
    39,541
    Works, but honestly doesn't do all that much.
    Feb 2005
    California
    6,544
    If you put on 1.7 roller rockers, will they clear the stock valve covers or do you need to get taller valve covers? And if so, what height of a valve cover do you need?
    Nov 2014
    Evans, GA
    1,636
    Stock covers work fine.
    Feb 2005
    California
    6,544
    OK thank you.
    Oct 2008
    Buffalo, NY
    4,991
    My 91 Battle Wagon had all of the above in lopo form. Still ran a 16.3 @ 275k miles on the old girl.
    Moral of the story, unless you already own them, or get them cheap, and are doing valve cover gaskets, not worth it. if your doing a HO intake/TB/bored EGR spacer, and want to replace the VC gaskets, a great time to throw them on.
    39,541
    agreed, I wouldn't go out and buy them just to try and make power on an otherwise stock engine.
    Member ZackN920's Avatar
    Jan 2020
    Northern IL.
    71
    I've looked into these myself for other engines. I've found that if you are buying new, there's not much 'bang for the buck' here. Way too expensive for the outcome. I don't know if that's the same case here with the Ford engine's but I would imagine so.
    1987 Lincoln Town Car Signature Series-98k miles- LOPO 302, AOD, open 3.27, Dual exhaust w/ Thrush Turbo mufflers
    the others...
    1926 Dodge Brothers Business Sedan- 212ci I4/3 speed/crank start
    1987 Dodge Dakota- 3.9/A999/3.90/2wd (storage)
    1990 Jeep Grand Wagoneer-AMC360/727/NP229/3.08/2" lift(daily)
    1994 GMC Burban L05 350/4L60e/241/3.42
    2001 Jeep Cherokee 4.0/AW4/231/3.73 (limbo)
    39,541
    I bought a set of Crane ones for an HO a long while ago. About all I really got was a bit of extra noise. Eventually it was a lot of extra noise as they wore out. I have a set of Scorpions now. Had them from another set of heads I'd bought and when I realized how slapped out the Crane parts were, I stuck them on because I needed something to make the valves open. I had them and they fit under my valve covers. My backup plan was to clean up a set of stock stamped rockers and bolt that together.
    Jan 2007
    10,380
    Odd because I had to clearance the covers and the end rockers so they didn't hit. Maybe the edelbrock heads are different. I know the crane rockers will clear no problem.
    39,541
    i was expecting problems and was just happy when it worked. for all I know its missing by the thickness of a sheet of paper, but I don't really care.
