86 CV stalling when under load
    When getting the 86 Crown Vic out of the garage during the first really nice weather last week, an annoying issue cropped up.
    It starts and idles fine, but as soon as it's under load (shift into drive) it stalls (or very nearly stalls).
    When applying a bit of gas, it surges then is fine so long as it's being driven, but then nearly stall again once stopped and no gas is applied.
    I thought it was a MAF sensor issue (as I had a very similar issue with the 99 MGM and my 03 Town Car and a quick cleaning temporarily fixed the issue until I just replaced the sensor), but these don't seem to have a MAF sensor. Or am I wrong and it's just somewhere weird (in the throttle body etc...).
    Any other thoughts?
    Thanks.
    No MAF sensor, but there is a MAP sensor that might be worth investigating. It's located on the firewall behind the passenger side of the upper intake. I assume that it's in the same place on '86, otherwise it might be on the passenger fender like some of the older models.
    Make sure the vacuum line to the MAP sensor is good. Unplug the sensor and if nothing changes the sensor may not be working.
    http://www.grandmarq.net/oldfuelinjection/page10.html
    http://www.grandmarq.net/oldfuelinjection/page4.html
      It is there on an 86 in the same location but on a different bracket that orients it differently.
        sounds more like a sticky IAC to me. Tubular thing on the back side of the throttle body. Pull and clean it. Its the idle air controller. If that doesn't move, the idle doesn't adjust correctly.
          I agree with MAP and IAC, but I also suggest a visual inspection around the intake manifold area for broken or damaged vacuum lines (or evidence that mice may have snacked on them). A bad vacuum line can cause the appearance of a bad MAP sensor, even if the leak is somewhere else. If the vacuum lines all look good and there's no evidence of a vacuum leak (especially check the lines and connectors in the fender area by the EGR solenoids) then check the IAC and make sure the wiring/plug connected to it are in good shape; then clean it as mentioned above, and if those don't fix it start looking at IAC, plugs, wires, cap and rotor, and TFI module in that order. With a car this old (mine is also an '86) it's not wise to assume anything is good or bad until you've put your fingers on it at least once.
            Thanks for the tips.
            I'll check those few things later today or this weekend
              The IAC was pretty dirty, with a bunch of soot/carbon coming out when I hit it with some MAF sensor cleaner. Put it all back together and it seems to be a lot better.
              I'm going to take it for a spin when it stops raining to see, but a few shifts and rd vs in the garage seemed to indicate the issue is resolved.
                The car now drives great. Just like new.
                Thank you for the advise and tips.
