Results 1 to 9 of 9
Thread: 2006 4.6 in a 2000 CV
    bigger is better over2tonsofFun's Avatar
    Nov 2007
    Laramie, WY
    254
    Default 2006 4.6 in a 2000 CV
    With the motor in my 2000 toast. I have been looking for a 4.6 to put in her. I found a 2006 4.6 motor with similar mileage. Will a 06 4.6 work in my 2000 Crown victoria.
    Thanks
    Tim
    2000 Ford Crown Victoria
    89 Lincoln town car: RIP
    1990 Mercury Grand Marquis LS
    Yes but you will have to swap your fuel rails and plenum over to the new motor.
    22,068
    +1 fuel rails and throttle body and intake elbow. Use the newer intake manifold. You should keep your own accessories (AC compressor, power steering pump, alternator). The newer water pump and pulley will line up with the older accessories. That alignment was the same for all 4.6 engines. You may also have to swap out sensors depending on if the connectors are different - IE: coolant temp sensor, cylinder temp sensor (driver side head behind the alternator), cam sensor. You will need to keep your old injectors unless you plan to tune it.
    Hobbit
    Dec 2006
    Ontario, Canada
    1,338
    Oil pan, oil pickup tube and exhaust manifolds will also have to be swapped over. You will also likely have to swap the aluminum crossover pipe from your old intake to the new one as it has additional hole for second temp sensor.
    Nov 2007
    Laramie, WY
    254
    Would it be easier using a 2004 4.6
    Hobbit
    Dec 2006
    Ontario, Canada
    1,338
    Quote Originally Posted by over2tonsofFun View Post
    Nope. Any 2003+ will require same amount of work. It's not very difficult though. Everything is a straight bolt on. Might not be a bad idea to replace valve seals, intake and exhaust manifold gaskets at the same time.
    22,068
    Quote Originally Posted by Mr Bean View Post
    Can drill and tap the flat boss on the side near the thermostat for the older temp sensor. That's what I did with my 93 and the 03 engine swap.
    Hobbit
    Dec 2006
    Ontario, Canada
    1,338
    Yea, that works too. I found it easier just to swap the crossover pipe. Finding a tap big enough is not easy where I live.
    22,068
    Fair point. Very easy to find in my area.
