Results 1 to 3 of 3
Thread: 5.0/aod is going out
    Default 5.0/aod is going out
    So ive been having issues with trans not shifting ( not slipping) its related to the tv cable i could never get it adjusted correctly. me being cheap never really got it fixed, well now my trans is slipping really bad and 2 of my cylinders are at <80 on a compression check. I do have a spare 4.8 gm motor and th400 trans just laying in the garage but havent seen many people ls swapping this car. Is the reason just because of the sin of throwing a gm engine in a ford? ive been looking for a decent 351w but cant find any here in the pnw for a good price, i can get another 5.0 but id rather just swap the 4.8 in there since i already have it.
    just curious has anyone swapped a ls based engine in? looks to be the same mounts as a fox body so was just thinking about using those for the swap and making my own trans cross member.
    Nov 2012
    Shelby Township, MI
    3,729
    If you have the fabrication skills to make your own crossmember I don't see a reason you can't physically do this swap. Very much of the swap info that applies to this swap in a fox body will likely apply to a panther as well.
    Beyond the reluctance of putting a GM powertrain into a Ford, these cars generally aren't owned by people with the resources to do such a swap (could be speaking for myself). Although I'm certain an LS swap has been done, but not by anyone on this forum as far as I know.
    Gone but not forgotten:
    41,311
    TV cable will have nothing to do with low compression, but low compression will make the engine run poorly and seem like the trans doesn't work well. 3 and 4 are directly locked so any poor running habits are very obvious.
    No problem on the 4.8, but I wouldn't use a TH400. Not enough gears. Assuming they even fit together, the TH400 went out of production a long time before the LS family was invented. I'd mate that to a 4L60e and roll with it if you're gonna. Standard grumblings about putting a GM engine in a Ford though. It ain't natural.
    engine mounts are completely different than Fox ones so those won't be useful.
