Results 1 to 5 of 5
Thread: Marge
    Member Grand1's Avatar
    Feb 2012
    Michigan
    748
    Default Marge
    Discussing some electrical issues with Phil and I belive its the alternator ....any way got it rebuilt and putting back together. So the 15 ft bottom alternator bolt, having an issue for it to seat in the back part of the bracket...got it one third in the front. Any tips? Do I secure the other bolts of the alternator bracket first?
    1987 LTD Crown Vic 351w aka the "MI Mountie"
    1979 Marquis creamy goodness
    Nov 2012
    Shelby Township, MI
    3,644
    I've had this issue a couple times. I just kept messing with it until I got it. Basically when it looked like the alt should be lined up it was not. I couldn't get the bolt out the rear of the lower alt ear as it was hitting the bracket instead of entering the hole in the bracket.
    If you're just pushing straight in and it won't go, sometimes screwing it in helps even though the bolt threads are nowhere near engaging the threads in the bracket.
    Just keep wiggling the alt around till it feels right is all I've got.
    Gone but not forgotten:
    Feb 2012
    Michigan
    748
    Yeah Vic, pry bar and silly rocking and forth. I know I am not a mechanic by any stretch but the four letters words tend to come out after a couple of hours. I am assuming the bottom bolt should be done first and then tension applied and top alt bracket bolt secured
    20,410
    I leave the lower bolt loose. Then apply tension...tighten the upper bolt... then snug up on the lower bolt. Doesn't make sense to me to strain against pivot point when applying tension to the belt.
    Sep 2014
    Warren, MI
    6,590
    Quote Originally Posted by Grand1 View Post
    ...I know I am not a mechanic by any stretch but the four letters words tend to come out after a couple of hours...
    As my one buddy used to say in regards to that, "Remember, we do this for FUN."
