Hard to Start 2000 MGM Only When Cold
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Hard to Start 2000 MGM Only When Cold
    Goal was 'giving back', done by 2020.
    Jul 2014
    Canada
    2,190
    Default Hard to Start 2000 MGM Only When Cold
    My 2000 MGM used to start super-fast even when cold, but by last winter, it hasnít wanted to start easily while cold, though it still does when warm. After fuel injector cleaner didnít magically work, I found the #8 plug was fouled in a way that the online charts indicate is from fuel additives or burning oil (lots of ash on the vertical part of the ground electrode), though the others looked fine. The plugs were well on their way to .056" at one-third of their lives, so I gapped them to .052". I then put in a new set of COPs, plus a new battery since a cell happened to crap out. (For those who strip the plastic holes for the COP screws on aftermarket intake manifolds, I managed to drill through the holes for cylinders 1 and 2 using a hand drill and resorted to zip ties.)
    The hard start when cold problem was still there, though it was obvious that the electrical side was working at or near its peak, so the car gods were happy with that. Multiple primes of the fuel pump havenít helped, so Iíve been figuring fuel injectors. I think at least part of the problem has been not driving much and not occasionally driving the much longer distances that I used to. I also hadnít used fuel injector cleaner in years since I never saw it on sale. Iím currently relying on fuel injector cleaner and driving with OD off, which might be doing some good. If things donít improve further, my next step would be to check the injectors using the Ď9V battery and carb cleanerí trick. I suppose I should make an effort to do compression testing too if it comes to that, though I donít foresee myself trying to fix a compression problem.
    I saw the same type of hard start issue raised in various other places where all kinds of other stuff was mentioned, but nothing else struck me as probably applicable. Unfortunately, I never saw anyone reveal what their problem ended up being.
    If someone happens to know of a flowchart or something somewhere outlining the sequence of things that should be happening in the startup process, or doesnít mind coming up with something like that, it would be very much appreciated, as would any other useful insights/suggestions. Dunno if I will ever figure out the problem, but I will certainly post a definitive fix if I find one.
    GMN Regular
    Aug 2018
    912
    Do you have any way of datalogging? It might tell you if a sensor is acting up.
    GMN Regular
    Oct 2008
    St. Louis, MO
    896
    When was the last time you replaced the fuel filter? If you've been dumping cleaners into the tank it may have dislodged some junk that found its way into the filter. Hopefully not the injectors.
    I'd replace the filter and take it on a good hard run and see what you get.
    23,605
    Check fuel pressure (can use a tire gauge, but you will destroy it as the gas will eat the rubber in the gauge - they will last long enough to troubleshoot the fuel pressure at the fuel rail). If you have good prime and pressure through the start process, it's not fuel supply related... if not, replace the filter first since that's typically the cheap option.
    When I had hard starts dealing with temps, it was the ECT being stupid. Didn't fail open or short so the ECM didn't throw a code. It failed static resistance. You can check to see if it's in the ballpark when cold with a multimeter on OHMS (resistance) settings.
    Should also check the ACT as well as either of those being in that failure mode will do stupid stuff like this.
    ECT: http://www.grandmarq.net/oldfuelinjection/page28.html
    ACT: http://www.grandmarq.net/oldfuelinjection/page29.html
    Nov 2012
    Shelby Township, MI
    3,799
    I'm thinking sensor(s) as well, but I don't know the 4.6 well enough yet. ECT and ACT came to mind but I'm used to the 5.0 and wasn't sure if the 4.6 has ACT sensor and. It experienced enough to know if temps affect MAF sensor.
    Gone but not forgotten:
    41,782
    Its got an air temp sensor but not sure if its part of the MAF or in the air cleaner lid. At some point it moved from the lid to being part of the MAF but I don't know when exactly. Pretty easy to tell, if there is not an electrical doo-dad plugged into the air filter box right next to where the air pipe bolts up, its in the MAF.
    Possibly just cleaning the mass air sensor will sort it if the signal from it is flukey. Same with the air temp sensor itself. They don't go bad that often but if they get gak on them for whatever reason it can screw with the readings.
    23,605
    2000 it's still on the air filter box. That didn't combine with the MAF until 03 IIRC. It's pin 1 and 6 in the combined one and still uses the basic resistance same curve from what I can tell.
    Jul 2014
    Canada
    2,190
    I have an Autel AL439, which has more than paid for itself by localizing misfires to particular cylinders when COPs crapped out without triggering a code. I had a look at the live data with engine running at one point and didnít see anything out of sorts, but it hadnít occurred to me to get readings before starting the engine despite knowing the temp sensors were a possibility (duh). When I checked, the IAT was correctly reading 1C while the ECT was reading 27C. Iíll verify with a meter eventually and let yíall know how it goes.
    The fuel filter was replaced some time ago and is not due yet. I had checked the air filter box to make sure it wasnít clogged and that the temp sensor was clean, and Iíll check that sensor with a meter too for the helluvit. A mechanic said he cleaned the MAF when he changed the plugs ~35,000 miles ago, and Iím always careful with the filter seal since the boxes tend to warp, so cleaning the MAF wasnít high up on my list without a can of proper MAF cleaner on hand.
    The fuel injectors could still be implicated if the fuel pressure is good, no? Iíve read that the spray pattern might be off enough to prevent ignition in a cold engine but not a warm one, but Iím no expert. Iím not going to bother cleaning the injectors if the coolant sensor is the problem, though the Ď9V battery and carb cleanerí trick is something I would do if I ever do the PI intake swap. Hereís a quick video to show how easy it is:
    Jul 2014
    Canada
    2,190
    Just when I thought I was going to get a break, the new coolant sensor from Ford is behaving the same as the old one. When the IAT was reading ~12C, the ECT was reading ~44C with a resistance of ~6kohms. When the IAT was reading ~2C, the ECT was reading ~33C with a resistance of ~8kohms, and the engine was still hard to start. This suggests to me that the new sensor is bad, which would be rather bizarre. Are the chart values in the links for the sensors standard for all makes of those sensors? If so, then I guess I have a clear case for a return based on the meter readings, which Iím guessing Iíll have to demonstrate conclusively since they donít allow returns for electrical parts.
    Curiously, there was nothing I could do to get a resistance reading from the IAT sensor, but the scanner shows it working properly. Does anyone happen to know what kind of witchcraft might be at play there?
    41,782
    The links are specifically about the 80s and early 90s units, I have no idea if they changed resistance but it wouldn't surprise me if they did not.
    try measuring resistance directly on the sensor if you can and see how that compares to what the scanner has to say. If you have some wiring gremlins it might be throwing the readings off through the harness.
    GMN Regular
    Aug 2018
    912
    Which sensor did you test? I donít know when Ford changed it but the early whales had a coolant temp sensor in the crossover and a cylinder head temp sensor under the intake.
    Stow It! GM_Guy's Avatar
    Ontario, Canada
    3,773
    Keep it easy on yourself re the sensors. Monitor the IAT and ECT temp via live data and drive it. Does it make sense for the length of drive you made? Keep in mind IAT will read higher than ambient depending on where the sensor is and as engine bay temperatures build up.
    And those temperatures you cited, those from live data on a stone cold engine thats sat over night before starting it? ECT wont take long to show on the sensor once the car is started if you had the engine running and got 32C reading.
    Ontario, Canada
    3,773
    Somewhat randomn, but where do you buy your gasoline from? More ethanol = harder start.
    Shell 89 might be upto 5% (stations that mix regular and premium) and Shell 91 is zero ethanol. Depending on geographical location shell regular might also have no ethanol.
    If you fuel up and any of the classic co-op style places (Co-op, farm supplier stations, Pioneer, expect ethanol in everything (that includes petro smell (worst offender in my opinion, they ruined sunoco 94 with ethanol when they bought them), and crappy tire)). And if you are in the habit of buying fuel at any hole in the wall place because its cheap, I'd be suspicious of water contamination.
    Jul 2014
    Canada
    2,190
    The temperature readings are from the scanner, and that was dead cold before starting the engine. The 12C was upon installation, and the 2C was after waiting a few hours. Both coolant sensors top out at 94C, which Iím guessing is normal.
    The resistance readings are from a meter at the sensors. Silly me, I have service manuals on a disk but had not looked to them sooner. It looks like the graph and chart are still valid, as seen in this screen shot from the 2000 manual:
    Iíll call the Ford parts counter to see what they have to say about the seemingly abnormal resistance readings. Another step would be to check the voltage available to the sensors when unplugged and what the voltage drop is across the sensors when plugged in.
    Iím pretty sure my car has the cylinder head temp sensor, though my guess would be that it is limited to detecting overheating and not involved in the start process.
    I generally get gas at Costco. I had suspicions about water initially, but nothing is really suggesting a fuel quality issue. Itís the kind of hard start where lots more cranking is required before the engine even tries to fire off. Iím inclined to think that injector, compression, or fuel quality issues would involve sputtering along the way, but Iím no expert.
    Jul 2014
    Canada
    2,190
    I tried another meter on the IAT sensor and got ~63kohms. I was able to replicate that with the first meter, so my problem was obviously something other than witchcraft. When I saw that, I had no doubt that the new coolant sensor was bad. The mechanics were already gone by the time I showed up at the parts counter with a meter, so I have to wait until tomorrow for them to verify the defect and order a replacement.
    23,605
    Bah. And humbug.
    Jul 2014
    Canada
    2,190
    I canít believe the problems Iím having with getting a coolant sensor that works properly. The rest of this post is from an email to Ford back in January (TL,DR - two sensors from a Ford dealer measured defective and the dealer was useless):
    I am writing about a problem with a defective part purchased from a Ford dealer parts department that will remain anonymous at this point. The part is a coolant sensor with part number SW-5174 for my 2000 Grand Marquis, though I understand it is used in various other vehicles too. Unfortunately, the new part had the same abnormal resistance readings at low temperatures as the original part on my car that went bad. When I returned the part, they did not take any step to verify the defect or pursue a warranty claim (contrary to my understanding) but rather just ordered another as a courtesy. I brought an ohmmeter to the parts counter when picking up the second one and was very disappointed to see the second part also had an abnormal resistance reading right out of the bag.
    One big concern for me (which makes Ford look absolutely ridiculous) is that they claim they have no way to verify if such a simple part is good unless it is on the vehicle. The service manual includes checking the resistance as a diagnostic step and provides a table with resistance values, so checking the part off the vehicle is really easy. I donít know what is more idiotic, a Ford parts department not knowing how easy it is to measure the resistance of a simple part to verify a defect or repeatedly being told that such a thing is beyond their capability.
    At that point, they were understandably not willing to obtain another part without going through the warranty process, which I was expecting to take a week or two. When I called today, I was told it typically takes a month or two. Further, the part was apparently not sent anywhere for inspection but might be if requested. And it turns out that if the warranty is approved, I would simply get my money back and still have to take a chance ordering yet another part from them with no guarantee that it will be okay upon arrival.
    For such a simple and relatively inexpensive part, the experience has been horrible. I doubt there is anything further you folks might be able to do in this case, but I just had to express my frustration. Fortunately, I donít drive much, and my car will still start with the original part after lots of cranking if the temperature is not too cold, but Iím in a situation that I simply should not be in. I would be interested in hearing what you folks have to say about this situation.
    Jul 2014
    Canada
    2,190
    The rest of this post is the seemingly useless response from Ford, to which I did not bother responding (feel free to skip it):
    Thank you for contacting the Ford of Canada Customer Relationship Centre. My name is Marisa and I have received your email on January 5th regarding your experience at a Ford dealership.
    We appreciate you taking the time to share your recent service experience at a Ford dealership and regret the circumstances for which you contacted us.
    Customers such as you, provide us with valuable dealer information to consistently achieve high levels of quality customer service. We regret to hear about the unpleasant events that you described which tainted your service experience. We believe every customer should be treated courteously, professionally, and with integrity in all instances. We regret any treatment that fell short of your expectations.
    Please keep in mind, Ford dealerships are independently owned and operated, therefore we are unable to intervene in workmanship issues. Therefore, we can provide your feedback to the Management Team as we believe they would also appreciate knowing the details of your dissatisfaction. However, due to insufficient information provided, we are unable to adequately provide feedback. Please provide us the name of servicing dealership to properly submit feedback.
    We understand the importance of your vehicle in your life and the subsequent challenges this part is causing you. We encourage you to remain in contact with your Ford dealership for any updates regarding obtaining a new part.
    We value your business and again regret for any frustration or inconvenience you may have experienced because of this situation.
    Thank you for contacting Ford of Canada.
    Jul 2014
    Canada
    2,190
    I managed to find only one aftermarket sensor in my area, and it measured defective in the same way as the rest. (I think they were all somewhere around the 6kohm range when they should have been something like 5-10x that.) I have no reason to believe that there is an issue with my meters, though I have not entirely ruled out the possibility in light of the freaky nature of getting three defective parts in a row.
    The mystery furthered today when I received a Ford part through Amazon. This one measured in the 2kohm range on each of two meters, which seems really bizarre.
    One possibility that came to mind was that defective ones that measured bad over the years were simply put back on the shelf, but that would only account for the aftermarket part that came in a box and not the Ford parts that came in sealed bags. I can’t imagine that these sensors are in any way time sensitive, so I would be really stumped if they had actually measured okay when they were made.
    Anyone have any idea what might be going on?
    23,605
    Part rot from sitting on the shelf for 10+ years?
    Sometimes new old stock isn't that great.
