Results 1 to 15 of 15
Thread: Hood Strut - Lift Support Recommendations?
  1. #1
    I post a lot...
    Dec 2011
    Yonkers NY
    4,680
    Default Hood Strut - Lift Support Recommendations?
    The hood struts on the 03 must go to their final resting place.
    I know there have been several mentions of replacement struts but I think they were kind of scattered in miscellaneous threads.
    So before I buy does anyone have any positive or negative recommendations?
    Thanks
    Jay
    03 Marauder DBP, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
    08 TC Signature Limited, HID's Mods>235/55-17 Z rated Cooper Zeon RS3-A, Addco 1" rear Sway, Posi, Compustar Remote Start, floor liners, trunk organizer, Two part Sun Visors, B&M Trans drain Plug, Winter=05 Mustang GT rims, Nokian Hakkapeliitta R-2 235/55-17
  2. #2
    Dec 2021
    668
    My friend needed them for his '96 CV and we sourced them from Amazon. Since they are all made in China, the decisions process is real easy. In any event, they are still "holding up" (sorry for the pun) and it is over 4 years later!
  3. #3
    GMN Regular
    Oct 2008
    St. Louis, MO
    859
    I went with the Stabilus brand on my 00 GP for the trunk and also on the hood struts. That's what came on it OEM and they lasted the longest. Also on some Fords as well. I sourced mine from OReilly's but other stores may sell them as well. Never had an issue with these.
  4. #4
    What a Luxury car should be. mercurygm88's Avatar
    Jul 2011
    The Firelands
    1,694
    The original loft supports on the Mark VI were fine when I bought it but they wouldn’t hold the hood up in cool weather. I got the Stabilus lift supports from O’Reilly’s. They’re just now coming up on a year old but they’re strong enough they almost open the hood themselves and my Mark VI has a steel hood. They also have a lifetime warranty.
  5. #5
    Sep 2014
    Warren, MI
    6,911
    I've got Stabilus struts on my '88. Put them on about five years ago, they're toast now.
  6. #6
    Mar 2010
    Lewisville, TX
    23,230
    I've had good luck with StrongArm lift struts. I've got them on most everything I have now. I've replaced things once with those (except the Mark VI that I sold to sxcpotatoes - that one required more due to the sheer heft of that trunk lid). Some are brandy new as of this year (rear of the Expedition - hood struts are about 5 years old - replaced right after I bought it) but the ones on the 93 have been there for over a decade now.
  7. #7
    Sep 2014
    Warren, MI
    6,911
    Thanks for the tip, sly. I'll look into them for replacements for my Townie.
  8. #8
    Dec 2021
    668
    As Popeye once said, "Ya puts up your money and ya takes your chances!" Not even sure any are still made in the USA so they are probably made in the same factory (China) and sold under different names. You "may" get some sort of idea, say like on Amazon reviews (with a grain of salt) and hope you gets years of service. They are quick to replace so merely see what happens.
  9. #9
    41,456
    Of the many sets I've tried on the Towncar, the only ones that worked are the Stabilus ones. Made the mistake of going with steel hood models since the last 2 sets of steel hood ones would barely hold the aluminum hood. Its actually hard to shut now.
    they are made in Turkey if you're curious. Branding on the package is Tuff Support. A product of Inseco, INC NY NY.
    something I did discover about the install on the Towncar, they are actually upside-down. The rod should be aimed downward, not upward like they are from the factory. The oil needs to get on the seal or it leaks.
  10. #10
    fomoco panthers !
    May 2011
    Bangor,Maine
    4,387
    Mounted upside down... Interesting. Might have to try that. Due to the cold weather here, hood struts do not last long for me. I have tried a variety of brands.
  11. #11
    I post a lot...
    Dec 2011
    Yonkers NY
    4,680
    Wound up ordering a set of the Stabilus as it was the cheapest, of Stabilus, Strong Arm & Tuff Support with shipping to me on Rock Auto which seems to have very good prices on these items.
    Also It is nice to use the closeout search feature by vehicle. Ordered some Valve cover gaskets & Oil filter for the Mercedes and an OEM Marauder air filter cheap. Plus I just couldn't resist a top line Standard Brand BOO switch for the Marauder for $4 even though I don't need one.
  12. #12
    41,456
    There are a lot of things on my shelf that were purchased purely because they were very cheap. I have an OEM NOS temperature switch for the Continental that I bought for like 3 bucks. I don't even know which of the three it is but I have one.
  13. #13
    I post a lot...
    Dec 2011
    Yonkers NY
    4,680
    just got these in.
    A pleasant surprise at the top of the picture!
  14. #14
    I post a lot...
    Dec 2011
    Yonkers NY
    4,680
    Well I recommissioned the Marauder today. Changed the struts when I got home. To my pleasant surprise they are identical to the original units with the exception of motorcraft printing.
ID:	58073Click image for larger version.
ID:	58074Click image for larger version.
  15. #15
    GMN Regular
    Oct 2008
    St. Louis, MO
    859
    Yep, and now there is no more hood wanting to eat your head/hands
