Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Red engine light
  1. #1
    Member 91merc's Avatar
    Jun 2022
    Oklahoma
    105
    Default Red engine light
    I got a red engine light on my 85 and it's acting sluggish, what's the difference between the yellow "check engine" and red "engine" lights on these cars?
  2. #2
    Member Stocker's Avatar
    Jul 2014
    The Land of Sky-Blue Waters
    146
    The red "ENGINE" light comes on when oil pressure is too low (below either 6 or 10 psi, if memory serves) or coolant temperature is too high (250F or above).
    1985 LTD Crown Victoria
    1996 Dodge Ram 1500 4x4, 360
  3. #3
    Nov 2014
    Evans, GA
    2,009
    Quote Originally Posted by Stocker View Post
    Yellow "Check Engine" on '89+ is an actual check engine lamp. Like Stocker said, the red "ENGINE" light is for one of those two issues.
    -1997 Grand Marquis LS (230K Miles) - The Daily Workhorse & March 2015 + January 2019 POTM Winner
  4. #4
    Jun 2022
    Oklahoma
    105
    Well the coolant temp sensor has bare wire on the little snap plug. And I might've disturbed it when I pressure washed the engine, oil pressure wiring doesn't look the best either
  5. #5
    41,571
    That would be the "replace engine" light. Unless its a bad sensor, fair bet she's fucked if you've been driving with that on for any amount of time at all.
  6. #6
    Jul 2014
    146
    Quote Originally Posted by 91merc View Post
    With the engine cold and running, disconnect the wire from the coolant temperature switch (this is the one on the intake manifold - the one on the heater hose fitting is the temp sensor for the ECU). If the light goes out, the problem is the switch. If the light remains on, either the wiring is shorted or the problem is in the oil pressure side of things. Disconnect the wire from the oil pressure switch - if the light goes out, either the switch is bad or your oil pressure is next to nothing.
  7. #7
    GMN Regular WagonMan's Avatar
    Sep 2004
    Bridgewater Ct.
    947
    Doesn't an 85 have the "low oil" sensor in the oil pan? The sensor can be stuck or the wire going to it may be shorting out. WagonMan
    89 Colony Park
    90 Colony Park
    70 HEMI Daytona Convertible
  8. #8
    Jul 2014
    146
    Quote Originally Posted by WagonMan View Post
    That's a separate light - optional on Fords, and I think it says "Check Oil" (my '85 is a low-series car and doesn't have it).
  9. #9
    Domestic Tourist Lincolnmania's Avatar
    Sep 2004
    Birdsboro PA.
    17,879
    does it go out when you rev it up?
  10. #10
    Jun 2022
    Oklahoma
    105
    The first time I drove it about 15 miles, parked it for about 10 minutes and it was on right from startup, then I went under the hood and wiggled some various wires and it stayed off for about 10 more miles, the last 5 or so miles there was no knocking or coolant smell, just a little sluggish
  11. #11
    Jun 2022
    Oklahoma
    105
    The light is staying off right now, but I haven't actually moved it at all yet
  12. #12
    Mar 2006
    Bedford, VA
    6,831
    If the coolant temp sensor or the oil pressure sensor grounds due to faulty wiring and/or a faulty sensor, the light will turn on. By what you are describing, that sounds like your issue.
    A steady on red engine light for actual temp or oil pressure reasons basically means turn it off ASAP or you're gonna nuke it.
  13. #13
    Jun 2022
    Oklahoma
    105
    I think you're right on the ground problem cuz it stayed off on my 20 mile commute to work and ran real good. If the ground problem is the case, would that basically fool the computer into thinking the engine was about to grenade and throw the car into limp mode and thats why it was sluggish?
  14. #14
    Dec 2019
    San Antonio, TX
    361
    Do these things have a limp mode?
  15. #15
    Jun 2022
    Oklahoma
    105
    Or is it rather to do with the fact that the coolant temp is one of the variables used for the air/fuel mixture?
  16. #16
    I post a lot...
    Dec 2011
    Yonkers NY
    4,696
    91, I am guess from your answer to Lincolnmania that the light does not go off if the engine rpms are increased?
    03 Marauder DBP, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
    08 TC Signature Limited, HID's Mods>235/55-17 Z rated Cooper Zeon RS3-A, Addco 1" rear Sway, Posi, Compustar Remote Start, floor liners, trunk organizer, Two part Sun Visors, B&M Trans drain Plug, Winter=05 Mustang GT rims, Nokian Hakkapeliitta R-2 235/55-17
  17. #17
    all the CFI are belong to me
    Feb 2014
    Windsor, ON, Canada
    2,366
    As mentioned above for the most part:
    The red engine light in a Ford (Mercury has two lights, Ford has one) represents either a low oil pressure, or high temperature, or both condition.
    The lights receive 12V at the gauge cluster, and the lights are turned on by the switches (like a "sender" but it is only on or off) grounding the wire.
    Oil pressure switch grounds the wire when oil pressure is below a certain pressure, from memory it's about 6psi. Therefore, the light is normally lit solid any time the key is on but engine is not running, and then turns off once the engine is running. As noted above, when an engine is worn, low oil pressure at idle that goes higher when you rev it is sort of normal (not good, but common as things get worn out).
    Temperature switch grounds the wire when temperature is above a certain amount, from memory it's about 260 degrees Fahrenheit.
    Reasons why the light can turn on:
    1. The oil pressure is low.
    2. The temperature is high.
    3. One of the switches is broken.
    4. One of the switches was mistakenly replaced with a sender. In parts store catalogs usually a switch is described as "with light" or "without gauge", and a sender is described as "with gauge".
    5. One of the switches is defective.
    6. A wiring fault is allowing the bare metal of one of the wires (oil or temp) to touch bare metal somewhere, which grounds the wire turning the light on.
    Sounds like #5 or #6 is your likely option.
    The computer has a temperature input, but it uses a completely separate sender. There is no interconnection between the red engine light in the cluster and the computer. They do not know that each other exist at all.
    A very hot engine will run sluggishly, but it is also possible you have an unrelated issue if wiggling the wire makes the light come on or off.
    Current drivers: 84 TC | 85 CS
    Panthers, Parked: 83 GM 2dr | 86 GM | 88 TC | 91 GM
    Not Panthers: 85 Ranger | Ranger trailer | 05 Focus
    RIP: 97 CV | 83 TC | 04 Focus | Junkyards
  18. #18
    Jun 2022
    Oklahoma
    105
    I think the bare spot in the wire to the coolant temp was touching the alternator bracket and grounding out
  19. #19
    Nov 2014
    Evans, GA
    2,009
    Quote Originally Posted by kishy View Post
    I’d just like to point out the Mercury clusters when equipped with all the warning lights and the check level oil sensor will only feature the single red engine light. The base clusters without the extra lights or when not equipped with the check level lamp will feature the split temp/oil warning lights.
  20. #20
    Jun 2022
    Oklahoma
    105
    that's exactly what happened, the little clip on plug for the coolant temperature rotated and the bare wire was touching the coil bracket
