Cfi performance
Page 1 of 3 123 LastLast
Results 1 to 20 of 47
Thread: Cfi performance
    Member 91merc's Avatar
    Jun 2022
    Oklahoma
    105
    Default Cfi performance
    Any simple, budget friendly ways I can give my 85 cfi car just a little more pep? Right now all I have done to it is an edelbrock chome air cleaner, smog/egr delete and a 12" glasspack in place of the factory muffler
    Dec 2019
    San Antonio, TX
    407
    Any chrome in the engine bay is an easy 10 hp.
    Dec 2021
    972
    Not sure there are a lot of economical upgrades you can do as this is a "dog" performance vehicle. Any real upgrades would not be cheap, wouldn't be worth the effort and would require several unnatural acts. Different exhaust manifolds and exhaust items would help (somewhat) but if you are not doing all the work yourself, is it worth it?
    Jun 2022
    Oklahoma
    105
    Quote Originally Posted by friskyfrankie View Post
    Not really look for a "performance vehicle " just a little more passing power lol. I'd be doing any work myself as me and my dad run a mobile mechanic business
    Jul 2019
    Finland
    1,517
    Dual exhaust is probably your best bet, headers might be pushing it, considering CFI doesn't play nice with mods, or so I've heard. My CFI didn't play nice even stock, and then there's @sluggish91 with a ton of mods on the stock CFI.
    I did away with CFI and now I'm running a 4bbl Holley, still running the stock single exhaust. Mid to top end definitely got more lively.
    Jun 2022
    Oklahoma
    105
    How well does the TFI / E coil ignition system play with a carburetor?
    Jul 2019
    Finland
    1,517
    Quote Originally Posted by 91merc View Post
    TFI doesn't work without a computer. TFI can be made to work with an MSD ignition box, but I'm not made of money. I'm using a Ford Duraspark II distributor with a GM HEI module, still using the factory TFI coil though.
    You can read more from my MGM thread, a couple pages back. I started the carb swap in April or so.
    Dec 2021
    972
    That surely helps. In that case, you can both do small incremental upgrades and see what they do. Just be aware the gains will probably be minimal.
    Jun 2022
    Oklahoma
    105
    How long did yours take? I can't have much down time as this is my daily lol
    6,877
    Sluggish91 has what is likely the most performance themed CFI build around here. His signature lists
    "CFI, K&N Filter, Edelbrock Performer 289 Intake, E7 Heads, BBK Shorty Headers, Summit H-pipe, Hooker Max Flow Mufflers, E-Fan, 3G Alternator, Race Crank Pulley, Bilstein Rear Shocks, KYB Front Shocks, Front Lowering Springs, FTI 2400 Stall Converter, PA Performance Valve Body, Motive 4.30 Gear, Eaton LSD Differential - I own quite possibly the fastest CFI powered box to the 1/8th mile: 9.95@68.89mph"
    At some point, he was considering a cam swap but I don't know if he ever completed it.
    Member Stocker's Avatar
    Jul 2014
    The Land of Sky-Blue Waters
    150
    The factory dual exhaust was supposed to be good for 15 hp. Trying to make performance upgrades with CFI, you'll eventually run into the limitations of the ECU programming.
    With CFI, just having it run properly is an achievement.
    1985 LTD Crown Victoria
    1996 Dodge Ram 1500 4x4, 360
    GMN Regular
    Oct 2008
    St. Louis, MO
    896
    I'd say dual exhaust gears/converter. Getting rid of 3.08's you likely have and getting into a 3.27 or 3.55 might wake it up, but I've never tried it on a LOPO CFI car so I may be disproven on that thought process. Beyond that it would involve dumping the CFI and going to a newer type system which is $$. Not sure but maybe a pair of stock Mustang exhaust manifolds would help? Just thinking outloud.
    Jan 2008
    New Jersey
    3,319
    Quote Originally Posted by FordMan77 View Post
    I agree with this and every one else. Rear gear change and dual exhaust will be the best bang for your buck
    Member sluggish91's Avatar
    Jun 2018
    California
    138
    Truthfully, it is not budget friendly to try to even make it remotely fast. Really, you get what you get with your CFI performance. I have a lot into my garbage but its been a great learning experience maximizing the limits of this system. As with any car, the entire combination plays a large role in how the vehicle performs. The way I've been going about my CFI build is I've been asking myself, "has everything around the CFI system maximized already?". Basically what I'm trying to say is make the engine put the power down before adding more power. Try and make the most of what you already have. Shocks. Rear springs. Poly trans mount. Brass terminal ignition coil. Copper plugs. weight reduction....?
    1985 2-Door: CFI, K&N Filter, Edelbrock Performer 289 Intake, E7 Heads, BBK Shorty Headers, Summit H-pipe, Hooker Max Flow Mufflers, E-Fan, 3G Alternator, ASP Underdrive Crank Pulley, Bilstein Rear Shocks, Rear Lowering Springs, KYB Front Shocks, Front Lowering Springs, FTI 2400 Stall Converter, PA Performance Valve Body, Ford Racing 4.10 Gear, Eaton LSD Differential - I own quite possibly the fastest CFI powered box to the 1/8th mile: 9.95@68.89mph
    1991 4-Door (Dad's Car): Pro-M EFI, 306ci, Ford Racing Aluminum Heads, COMP XE264HR cam, Cobra 1.7 Rockers, Edelbrock Performer RPM 2 Intake, 30lb. Injectors, Custom 65mm TB/EGR Spacer, Pro-M 75mm MAF, BBK Ceramic Shorties, Custom Summit H-pipe, Walker Mufflers, ASP Crank Pulley, Jegs Built AOD, 3000 Stall Converter, Ford Racing 4.10 Gears
    Jul 2019
    Finland
    1,517
    It could probably be a weekend-ish project if you're more experienced than me (quite likely), have all the parts ready and won't spend time painting valve covers, redoing all hoses, making 3 versions of a FP-regulator placement or cleaning up all the wiring in the engine bay.
    41,765
    just a minor point, the TFI does not need a computer to work. The problem is that you get no advance, which means it just works incredibly poorly without something to make that happen.
    ut yeah, gearing, dual exhaust, and probably the electric fan are the only cost effective mods to be made. I don't happen to like electric fans though, one more thing to go wrong. Also bad prior experience having one shit out and leave me fixing one of the heater hoses in a parking lot with no tools. Removing hoses with a dime and slicing the blown end off with a random rusty razor blade found on the ground isn't my idea of a good time.
    Jun 2022
    Oklahoma
    105
    Would it mess with the timing if I just left the whole system hooked up except the fuel injectors since there would be a carburetor?
    Jul 2019
    Finland
    1,517
    I've seen this done once, actually. Only problem is the TPS. That's gotta work or the whole system goes dumb.
    There are better and proven options. If you want to keep the TFI, you need an ignition box. The DS2+HEI combo I'm running costs very little; 60€ distributor, 20€ HEI module and a 30€ heatsink for the module plus a couple wires and connectors.
    Jun 2022
    Oklahoma
    105
    I'm thinking that if I do anything major to the car performance wise I'll just rebuild the 351HO that I have sitting in my garage and conver to 4bbl carb and use an electronic converted points dizzy or something
    Jun 2022
    Oklahoma
    105
    Also, one of those "higher voltage" yellow accel coils wouldn't do much would it? I have one in the box laying around
