Any simple, budget friendly ways I can give my 85 cfi car just a little more pep? Right now all I have done to it is an edelbrock chome air cleaner, smog/egr delete and a 12" glasspack in place of the factory muffler
Cfi performance
Not sure there are a lot of economical upgrades you can do as this is a "dog" performance vehicle. Any real upgrades would not be cheap, wouldn't be worth the effort and would require several unnatural acts. Different exhaust manifolds and exhaust items would help (somewhat) but if you are not doing all the work yourself, is it worth it?What I Own: 1993 Mercury Grand Marquis GS
Originally posted by friskyfrankie View PostNot sure there are a lot of economical upgrades you can do as this is a "dog" performance vehicle. Any real upgrades would not be cheap, wouldn't be worth the effort and would require several unnatural acts. Different exhaust manifolds and exhaust items would help (somewhat) but if you are not doing all the work yourself, is it worth it?
Dual exhaust is probably your best bet, headers might be pushing it, considering CFI doesn't play nice with mods, or so I've heard. My CFI didn't play nice even stock, and then there's @sluggish91 with a ton of mods on the stock CFI.
I did away with CFI and now I'm running a 4bbl Holley, still running the stock single exhaust. Mid to top end definitely got more lively.
Originally posted by Arquemann View PostDual exhaust is probably your best bet, headers might be pushing it, considering CFI doesn't play nice with mods, or so I've heard. My CFI didn't play nice even stock, and then there's @sluggish91 with a ton of mods on the stock CFI.
How well does the TFI / E coil ignition system play with a carburetor?
Originally posted by 91merc View PostHow well does the TFI / E coil ignition system play with a carburetor?
You can read more from my MGM thread, a couple pages back. I started the carb swap in April or so.
Originally posted by 91merc View PostNot really look for a "performance vehicle " just a little more passing power lol. I'd be doing any work myself as me and my dad run a mobile mechanic businessWhat I Own: 1993 Mercury Grand Marquis GS
Originally posted by Arquemann View PostTFI doesn't work without a computer. TFI can be made to work with an MSD ignition box, but I'm not made of money. I'm using a Ford Duraspark II distributor with a GM HEI module, still using the factory TFI coil though.
How long did yours take? I can't have much down time as this is my daily lol
Sluggish91 has what is likely the most performance themed CFI build around here. His signature lists
"CFI, K&N Filter, Edelbrock Performer 289 Intake, E7 Heads, BBK Shorty Headers, Summit H-pipe, Hooker Max Flow Mufflers, E-Fan, 3G Alternator, Race Crank Pulley, Bilstein Rear Shocks, KYB Front Shocks, Front Lowering Springs, FTI 2400 Stall Converter, PA Performance Valve Body, Motive 4.30 Gear, Eaton LSD Differential - I own quite possibly the fastest CFI powered box to the 1/8th mile: 9.95@68.89mph"
At some point, he was considering a cam swap but I don't know if he ever completed it.1990 Country Squire - under restoration
The factory dual exhaust was supposed to be good for 15 hp. Trying to make performance upgrades with CFI, you'll eventually run into the limitations of the ECU programming.
With CFI, just having it run properly is an achievement.1985 LTD Crown Victoria
1996 Dodge Ram 1500 4x4, 360
I'd say dual exhaust gears/converter. Getting rid of 3.08's you likely have and getting into a 3.27 or 3.55 might wake it up, but I've never tried it on a LOPO CFI car so I may be disproven on that thought process. Beyond that it would involve dumping the CFI and going to a newer type system which is $$. Not sure but maybe a pair of stock Mustang exhaust manifolds would help? Just thinking outloud.These are highly engineered precision vehicles, the first step in diagnosing the problem is to strike the suspected offending part sharply and repeatedly with a blunt object, then re-test.
Originally posted by FordMan77 View PostI'd say dual exhaust gears/converter. Getting rid of 3.08's you likely have and getting into a 3.27 or 3.55 might wake it up, but I've never tried it on a LOPO CFI car so I may be disproven on that thought process. Beyond that it would involve dumping the CFI and going to a newer type system which is $$. Not sure but maybe a pair of stock Mustang exhaust manifolds would help? Just thinking outloud.
I agree with this and every one else. Rear gear change and dual exhaust will be the best bang for your buck-Phil
Truthfully, it is not budget friendly to try to even make it remotely fast. Really, you get what you get with your CFI performance. I have a lot into my garbage but its been a great learning experience maximizing the limits of this system. As with any car, the entire combination plays a large role in how the vehicle performs. The way I've been going about my CFI build is I've been asking myself, "has everything around the CFI system maximized already?". Basically what I'm trying to say is make the engine put the power down before adding more power. Try and make the most of what you already have. Shocks. Rear springs. Poly trans mount. Brass terminal ignition coil. Copper plugs. weight reduction....?1985 2-Door: CFI, K&N Filter, Edelbrock Performer 289 Intake, E7 Heads, BBK Shorty Headers, Summit H-pipe, Hooker Max Flow Mufflers, E-Fan, 3G Alternator, ASP Underdrive Crank Pulley, Bilstein Rear Shocks, Rear Lowering Springs, KYB Front Shocks, Front Lowering Springs, FTI 2400 Stall Converter, PA Performance Valve Body, Ford Racing 4.10 Gear, Eaton LSD Differential - I own the fastest CFI powered box to the 1/8th mile: 9.658@70.74mph
1991 4-Door (Dad's Car): Pro-M EFI, 306ci, Forged Pistons, Ford Racing Aluminum Heads, COMP XE264HR cam, Cobra 1.7 Rockers, Edelbrock Performer RPM 2 Intake, 30lb. Injectors, Custom 65mm TB/EGR Spacer, Pro-M 75mm MAF, BBK Ceramic Shorties, Custom Summit H-pipe, Walker Mufflers, Jegs Built AOD, Roadrunner 3000 Stall Converter, Ford Racing 4.10 Gear - Best 1/8th mile time: 9.76@72.03
Originally posted by 91merc View PostHow long did yours take? I can't have much down time as this is my daily lol
