Parts exchange
Results 1 to 5 of 5
Thread: Parts exchange
    Member Shayenne's Avatar
    Sep 2013
    London ON Canada
    63
    Default Parts exchange
    Hi all,
    Unfortunately I had to retire my 95 Lincoln Town Car. My question is, can I take parts of this car and use them on my 98 Grand Marquis? Both have the 4.6l engine.
    I also have brand-new exhaust manifolds for a 2004 Grand Marquis, will they fit on the 98 Grand Marquis? Again same engine.
    And I want to take the AC parts off the Lincoln and put that on my 1988 Lincoln Town Car, will that work? The 88 has a 5.0l engine though....
    Sent from my SM-G950W using Tapatalk
    1995 Lincoln Town Car Executive Series: "Albert" my daily driver
    1988 Lincoln Town Car Signature Series: "Don Vito Corleone" my Summer Cruise
    2004 Grand Marquis LS: "The Boss" with floor shifter (loved it) - R.I.P.
    1997 Crown Victoria: "Victoria, the Armadillo" R.I.P.
    2003 Lincoln Town Car: "Nikkatello" - R.I.P. (Miss you the most)
    1995 Grand Marquis: "Gustavo Gonzales, the dirty Mexican" - R.I.P.
    Hobbit
    Dec 2006
    Ontario, Canada
    1,404
    Depends what parts you want to use as there were changes over the years.
    Exhaust manifolds won't fit.
    AC Parts won't fit.
    23,664
    2004 is actually a different engine. It's an upgraded version of the 93-00 engine. Same displacement, but very subtle differences that parts don't fit quite right. There's also other accessory issues on each engine as well as the years roll by.
    Parts from the 95 to the 98... not a lot. There's a few bits here and there, but mostly, nothing crosses over. Major change years are 89-90 (box changes being made to make aero production easier - floor pan, dash), 91-92 (transition from box to aero), 94-95 (mainly interior, rear exterior, and engine intake changes), 97-98 (transition from aero to whale - rear axle mounts differently), 00-01 (upgraded engine), 02-03 (Front subframe design changes).
    +1 AC parts won't fit a box.
    41,825
    you might be able to make the condenser fit. Maybe. Pretty much none of the rest of it drops in though.
    23,664
    That would take some fab work... cutting off the brackets on the 95 condenser and notching the left side ... if the coils don't take up that location. The Aero condenser is also 1.25 inches taller and may not actually fit in the hole in the box. The line fittings are the same though.
