Mark VI smog pump bypass
Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Mark VI smog pump bypass
    What a Luxury car should be. mercurygm88's Avatar
    Jul 2011
    The Firelands
    1,722
    Default Mark VI smog pump bypass
    The smog pump on the Mark VI finally locked up tonight and broke the belt. Good riddance I say, it will be going away in the near future. My question is can I run a shorter belt and run the A/C or do I need a bypass pulley of some sort in place of the smog pump? Also where is the tensioner for that belt? If it's like the one on my '88 Grand Marquis was I feel like there was a bolt to loosen the tensioner pulley and another to adjust it? Maybe I'm thinking of something else. Also if anyone knows the length of belt I'd need to bypass the smog pump it would be greatly appreciated.
    23,627
    Shorter belt and just run the bottom length of the belt over the tensioner pulley. Don't remember of the top of my head which length belt is the one to use though. It's listed in plenty of the smog delete threads though.
    23,627
    from my search, it looks like k060565 (56.5 inch). Wait for confirmation though.
    Jul 2019
    Finland
    1,521
    I used a 56,1" belt after the smog pump delete, I run the belt underneath the tensioner pulley.
    It could've been a slight bit longer, was kinda hard to get it on over the edge of the pulley with the tensioner completely loosened.
    For tightening the tensioner has a slotted bolt on the backside of the bracket, loosen that and the pivot point bolt on the front side, normal 3/4" square drive hole on the tensioner to tension it and tighten bolts.
    Running the belt over the tensioner might be smarter for less belt bouncing, but I have it underneath the tensioner, since that's not putting weird stress on the tensioner. Dunno how, but I did somehow manage to bend the previous tensioner.
    23,627
    Yeah, I ran it over because after the smog delete, having the belt running by that gaping hole just looked weird to me. If you are leaving the smog pump in place for a while, I think over is also better for clearances. It might clear, but I don't remember.
    Jul 2011
    The Firelands
    1,722
    Thanks for all the info. The car is going in the garage for the winter next week. I’ll probably make the smog delete a project for a nice day that I’m off work.
    Jul 2011
    The Firelands
    1,722
    Well I got the belt on on my lunch break 56-7/8" was the closest belt I could find in stock. I ended up running it under the tensioner, so far so good. I'm probably going to see how far I can get on deleting the pump itself after work tonight.
    Jul 2011
    The Firelands
    1,722
    Smog delete complete, easier then I expected. I even put nice new bolts in the MAP sensor bracket.
    GMN Regular slack's Avatar
    Mar 2013
    Long Island, NY
    1,429
    Nice! Glad to hear it was an easy process.
    Sep 2014
    Warren, MI
    7,075
    Post pics, please! Might have to do that to my '88.
    Jul 2019
    Finland
    1,521
    @mercurygm88
    Did you remove the smog pump before installing the belt? For me, running the belt under the tensioner would mean the belt would hopelessly run into the body of the smog pump.
    @Derek
    Can't you see the pic I attached in my previous post?
    Sep 2014
    Warren, MI
    7,075
    Yah, I guess his would be a different version of the same thing, eh? Your post says you ran your belt under the tensioner too, looks that way as well. Anyone run it over the tensioner?
    In any event, I'm excited to tidy up the engine bay some.
    Jul 2011
    The Firelands
    1,722
    I'll post a couple when I get the chance. I pulled the pulley off at work with an electric ratchet and installed the belt. Then I removed the pump, hoses, and solenoids when I got home. I don't know if the smog setup on SEFI cars is different but I feel like everything on the drivers fender of my '88 looked totally different. The smog pump on the '88 was slightly different as well it had vacuum hose running to the cruise control servo. The one on the Mark VI just had the 3/4" hose running up to the solenoids and check valves on the fender.
    Also i know it's not correct and "unprofessional" but I also removed the plugs going to the two fender solenoids and the EEC III test port plug. I have no use for them and they just looked bad, so I cut them out and taped everything up. The only thing there now is the MAP sensor which I may relocate to clean the area up even more.
    Jul 2011
    The Firelands
    1,722
    @mercurygm88
    @Derek
    On mine half of the belt was rubbing the front edge of the smog pump pulley, so I grabbed an electric ratchet and removed the pulley.
    41,798
    yeah the pulley is pretty much in the path, but 3 bolts gets that out of your way. Same problem on Fox cars if you ever have to do it on one of those, but same fix.
    Jul 2011
    The Firelands
    1,722
    Here’s the inner fender after the delete.
    Sep 2014
    Warren, MI
    7,075
    Yeah, that looks much better. I remember my '85 had some hemorrhage looking thing sitting on the fender with multiple hoses going to it.
    Jul 2011
    The Firelands
    1,722
    Yeah there was a large check valve contraption there with three 3/4" hoses going into it and a couple of vacuum solenoids.
    41,798
    the plumbing and controls is pretty much the same EEC-III vs EEC-IV. Slightly different parts but they do the same job and its all a big clusterfuck.
    23,627
    +1 CF
    I did not miss any of that stuff when I took it off the 88 I had.
