3G Alternator Belt Squeal
    I must be the only person who owns a box that just put a 130 amp on without grinding anything or using an odd size belt...
    I used the same belt I had with my original 2G as well. I ordered an alternator from a Windstar or something though, should have went with the Mustang one. Windstar unit has a boss or tab on it for something else which doesn't allow a person to adjust all the way (if needed).
      Tortise alt has one of those too, but I don't seem to remember it being really in the way. The Mustang one doesn't swing quite all the way over either but it never seemed to be a big problem.
        I've never done any grinding on my brackets, but I have ran the stock box sized belt. All three 3Gs that I have had all had a different size pully. Not much different but enough that I was not able to run stock sized belt on all of them.
          Mine was eventually swapped to an original 2g pulley. Those are slightly smaller. with the underdrive crank pulley I was having problems at night when I had the electric fans still. The smaller pulley gave it a bit more speed and helped. Removing the electric fan helped more though.
            That’s a good pulley to use as I believe it’s 1.9 inches in diameter. You want as much alternator shaft RPM at idle as you can get without over speeding it at redline. 1800-2000 RPM is a good target. Some sources say 15000 RPM others say 16000 RPM for max shaft speed.
            With how slow our engines idle and with our 4200 RPM redlines we need those small pulleys.
              Mine will wind up to a solid 5500 but with an underdrive crank pulley I don't know what rpm the alternator ends up at. Offhand I do not remember how big it is so I can't just do the math. The underdrive crank pulley went on after I blew up a heater core at somewhere north of 100 mph in third gear. If you've never had your windshield go opaque at a high rate of speed, I can tell you its exciting in all the wrong ways.
                I'm thinking when I have mine replaced I'll put a valve in line with it so I can bypass it for summer. I don't really drive the thing during the winter. Non sloshy days are rare around here during the winter.
                  I’ve never had that happen but can imagine it wasn’t very much fun at the time! Makes for a good story and glad you got the car stopped!
                    Sly found some nifty vacuum controlled valve that can be installed to auto-bypass the core when it gets vacuum applied. I want to say he had it plumbed so it shut the core off when AC was in recirc mode but forget specifics. Can prob find the thread on here somewhere. Should give a boost to AC performance especially if the air door seals are imperfect. Can't just shut flow off with a simple valve, the ECT is in that line and no flow will cause that to never heat up. The ECM will mess up the fuel mix if it thinks the engine never gets up to temp.
                      No grinding here either. The only thing I had to do was get an alternator bracket from a 100amp alternator equipped cvgm as I got a large case 3G from a taurus.
                        Ranger/Explorer heater control valve. Part number 74809. Apply vacuum to bypass heater core.
                          OOo nifty. Thank you sly & gadget
                          What to tee off of for vacuum when in recirc mode? That's pretty much all I use, only I don't have the ability to manually engage it since I have ATC, so full cold running low or medium blower speed usually keeps it in recirc.
                            maybe the air door for the dash vents. Unless you use those with hot air. Tying it to the recirc door works in the summer but if you set it for full heat that also goes recirc and would kind of defeat the purpose.
                              Guess I could just do a manual bypass valve. I do indeed do full hot, well, before the heater core blew a hole in itself and I stopped driving it when cold.
                                I ran the thing off panel vent vacuum. Don't need heat when blowing it in my face in the middle of summer.
