So after I replace the balljoints I notice I have an engine knock
It's loudest underneath the car. It only does it if you're freerevving in park at or around 1700RPMs, and in between shifts when driving. I don't hear it at all at Idle or WOT.. It also doesn't do it at all if the engines cold, only after about five or ten minutes of runtime. How hard is it to pull the pan? I'm not sure I can afford an engine swap..
For now I think I'm going to try maybe 10w30 and maybe some Marvel Mystery oil or some lucas..Will the thicker oil hurt it? If it's easy enough I could pull the pan and check out the bearings, but I'd need some help for that as I've never torn into a motor that far. I'm just trying to get rid of the knock for the time being. I just started a new job and can't afford major repairs..
