No problemo. I should have actually noted that the PCV valve is one of those parts that is worth sticking with OEM.
I usually stick with Motorcraft; or whatever came off the stock engine. Unless it's the '86 CV; and if the OEM Motorcraft parts are no longer available.
Yep, gonna be doing the intake manifold in the Spring. Getting a bit of steam coming from the back of hood. I think it's coming from the back of the intake; I saw it bubbling when I first fired up the MGM after the coil and plug replacement. Had to replace quite a bit of coolant this morning too. I hope it's not filling up the plug wells again.
Probably the heater core nipples in the back, that's where it split on my '98. Freaked me out so i just had a shop do it. In hindsight it didn't look all that hard but i mostly had no time to deal with it.
