So a guy I know accumulated all the parts to put a supercharger on his Marauder. I have the option to buy it all for $1100, but I want to know what issues I would run into beyond plenum direction. He has a Kenne Belle boost pump, 39 lb injectors, cobra intake, supercharger, 90mm MAF, and throttle body. Help/advice?
Marauder supercharger crossover?
2010 Mercury Grand Marquis LS “The Douche” - 70mm throttle body, P71 airbox, 21mm rear sway bay, dual exhaust, Dodge rims, 89K and counting. 4/2018-
1966 Ford Thunderbird (390FE) “Fordy McFordface” - engine rebuild No. 3. 11/2016-
RIP 2005 Buick LaCrosse CXS “Jumba” - gone too soon, 229K. 6/2017-2/2018
RIP 2001 Chevrolet Tracker LT “Featherbrick” - gone too late, 156K POS. 6/2016-9/2016.
Sold 2005 Toyota 4Runner SR5 - 198K. 6/2016-4/2018Tags: None
"A guy I know.. Him and her got IT ONN, WHOOO-EEEE!"
-"No they didn't."
"No, no they didn't. But you could imagine what it'd be like if they did huh?? Huh?!"
Sorry man, I know that's not what you're looking for but couldn't resist.1985 LTD Crown Victoria - SOLD
Originally posted by DerekTheGreat View Post"A guy I know.. Him and her got IT ONN, WHOOO-EEEE!"
-"No they didn't."
Sorry man, I know that's not what you're looking for but couldn't resist.2010 Mercury Grand Marquis LS “The Douche” - 70mm throttle body, P71 airbox, 21mm rear sway bay, dual exhaust, Dodge rims, 89K and counting. 4/2018-
Not sure but you may need a different or modified throttle cable, obviously have to move things like MAF wiring to the other side and relocate battery. Aside from that, it would be incidentals, although you may need different fuel rails. MM.net would likely have all the info you need. Or even CVN perhaps. Just be careful, some people there are dicks.
I’ll have to look through CVN again. Their shit is still down, otherwise 8 would have asked there first2010 Mercury Grand Marquis LS “The Douche” - 70mm throttle body, P71 airbox, 21mm rear sway bay, dual exhaust, Dodge rims, 89K and counting. 4/2018-
4 valve vs 2 valve heads. You would need a different intake manifold unless you swapped in a 4 valve 4.6L. Other than that (and the aforementioned intake direction issue), everything should work after being tuned to no more than 6-8 PSI. I wouldn't trust the stock internals beyond that.
Alright, intake was the biggest flaw I could think of.2010 Mercury Grand Marquis LS “The Douche” - 70mm throttle body, P71 airbox, 21mm rear sway bay, dual exhaust, Dodge rims, 89K and counting. 4/2018-
Did the parts search. No intake sales I could find recently even close to what I could afford. Looks like I will stay N/A for a while linger2010 Mercury Grand Marquis LS “The Douche” - 70mm throttle body, P71 airbox, 21mm rear sway bay, dual exhaust, Dodge rims, 89K and counting. 4/2018-
Originally posted by ClayBelt View PostSo a guy I know accumulated all the parts to put a supercharger on his Marauder. I have the option to buy it all for $1100, but I want to know what issues I would run into beyond plenum direction. He has a Kenne Belle boost pump, 39 lb injectors, cobra intake, supercharger, 90mm MAF, and throttle body. Help/advice?
Originally posted by Elias View PostAll marauder parts for the eaton swap for 1100$ thats cheap where your conection2010 Mercury Grand Marquis LS “The Douche” - 70mm throttle body, P71 airbox, 21mm rear sway bay, dual exhaust, Dodge rims, 89K and counting. 4/2018-
Originally posted by ClayBelt View PostCanadian who is selling his Marauder. He has a stroker kit he is looking to ditch too. Apparently that shits fairly cheap up there, and marauders are not much more special than crown vics. Shipping it across the border would be like $500, so I would have road tripped during fall break.
Originally posted by ClayBelt View PostApparently that shits fairly cheap up there, and marauders are not much more special than crown vics.
Alex.
