I'd say backhalf it with tubs.
Project Harvester of Sorrow. Update 2/20/09, Rebirth??
Ok Cam lifter and main studs should be here tomorrow, then on the 28th I am getting the pistons and rods. When those get here, THen he block and heads get dropped off. So by the second friday of August, I should have en engine almmost ready for Dyno.2008 Mercury Grand Marquis GS Bone Stock
The modern definition of "racist" is "someone who is arguing with a Liberal".--updated Peter Brimelow quote.
Have the machine shop change out the cam bearings for you too. Usually its fairly cheap to have done, and the tool is over $100 most of the time.86 Lincoln Town Car (Galactica).
So it's gonna be a stroker...
4.5" Eagle crank $260
6.605" Eagle Rods $251
Seeing "NOS the Blown Kid" cry when he get his ass whupped by grandpas car
PRICELESS!!!!2008 Mercury Grand Marquis GS Bone Stock
Actually, with a port match to the intake, They are not gonna be too bad. Next year I'll get the SCJ's but the D3VE's will work till then. I actually think that I'll see 430hp and about 600tq on the stocker heads. Then agian I could port then all the way and have bigger valves installed, but that would be breaking my engine budget.2008 Mercury Grand Marquis GS Bone Stock
Why does everyone think the later heads are so bad? Are the ports different size? They have the same valve size as the earlier heads. And the bumps in the exhaust ports can be ground out. The thing I see that is the down side would be the combustion chamber size. The later heads are 96.2cc compared to the earlier's 75.8cc.
And that can be cured with domes!!! All they need is a port maching, and a good shave and that is it! Hell if I like the power I get with the D3VE's, I probably will not get the FRPP SCJ's. All they save is what 80 lbs? The stockers arent all that heavy, hell the heads on my 454 were heavier!Last edited by RugerP97DC; 07-20-2006, 03:30 AM.2008 Mercury Grand Marquis GS Bone Stock
HOS 460 Plan
OK here is the setup
4.5 Crank
6.7 Rods
4.44 Pistons
Vodoo Cam*
Weiand Stealth Intake
Edelbrock Thunder AVS 800cfm
MSD box
MSD Distributor
*=arrived
In short, this is a .080 overbore 557cid BBF.
on
That is what I though, untill I talked to quite a few Ford guys. Tuens our the old 385 blocks were intentionally made with lots of iron. The 2 widley avalible overbores are .030 and .080! I was timid about it untill I saw a block withe the same casting as mine that had a .100 bore on it! (With the stroke it has it's over 600 cubes!)
I still have to find the right pistons. I want the hyperturetic or cast, simply for the cost. I may yet end up with only a .030 an a 4.3 crank, but it will still be a freaking monster.
Oh and I am meeting a chassis guru this week to talk about the mods to a PANTHER, as the Mustang is to short for the weight of the engine. I dont want to end up spending 2500 buck on a front end for a fox!2008 Mercury Grand Marquis GS Bone Stock
