Ok I finally got my Hanyes Manual in and I'm ready to do my brakes. I need to turn my rotors so I will pull them off and get them machined then Fresh pads. What Pads would you guys recomend? I will check and repack my wheel bearings and I may have questions later has I have never done this. It kind of says in the manual. I am going to change my diff. fluid this weekend too. I have trac lok so what brand and what weight of gear oil should I use. I also need to use friction modifer right cause of the trac lok? Then Later on I am going to get some HH springs (those are the ones that give you like a inch and a half more rake in the back right?) Then comes to the shocks. I don't need them but I would like to improve handling. What should I get, Bilstein HDs or Edlebrock IAS shocks. What is the best bang for the buck? Kind of alot of questions but any help would be great.
Thanks
Zack
Thanks
Zack
