well i was going to go out, cop followed me for a few blocks and pulled me over, was like, i pulled you over cause your brake lights are out, not the center one but the two outside ones... got home, checked the bulbs, all good, cant seem to find the fuses listed in the owners manuel and i cant find my FUCKIN VOLTMETER!
no brakes!!
So the third brake light works and the two outers do not? Does it change any if you fool with the turn signal switch or the hazard switch? Might be a bad multifunction switch. I've seen GM cars do just this with a bad MF switch.86 Lincoln Town Car (Galactica).
correct, high center works, outboards are dead, though the same bulbs light up for parking lights.Originally posted by gadget73So the third brake light works and the two outers do not? .
no they still dont work even when i dick with the hazard or turn signal
oonly thing i was thinking, was my uhaul wiring. my uhaul trailer wiring has worked for years, well ive used it 3 times, last time around christmas. brake lights worked fine up till at least a few days ago.
someone wanna repost this on CVN? i cant. need to get this fixed its my only car and ive got a car thats kinda worth shit to me right now. its a p73 2001 vic
Multifunction Switch- Turn signal/emergency flasher (button on top of column)/wiper/dimmer/flash-to-pass switch.
Hell, just turn the flashers off & on a time or two & the brake lights will likely start working again for a while.:worship: Aeros r00l.
All my service manual info still points toward the MFS or a wiring short. And you're sure all bulbs are good? I would check in the trunk first, around your uhaul installed trailer wiring, and maybe even remove it temporarily, but also anywhere anything else has been installed or removed recently that a wire could have been cut, especially in the door jambs on the driver's side.:worship: Aeros r00l.
sorry about that bmfer dude, my internet connection took a shit after i went out to the car
1. nothing done to the car at all lately.
3. turn signals for the uhaul are working but no power to the brakes. that wiring is such a small guage i didnt wanna go poking at it too much but i wasent getting any voltage for the brakes still. well im gonna go lookj some more. wonder if uhaul would look at it.....
but you were saying that there is only one wire going to the brakes? so if my center brake light is lighing up, then it would have to be between there and the tailights?Last edited by DanHool; 07-20-2006, 02:56 AM.
went to uhaul, looked over everything with the guy and all was good with the trailer harness
went to ford dealer, put in all new light bulbs, same shit
BRAKE LIGHT SWITCH MAYBE? i dunno, im going to be out of town from tonight till the end of the month
went to lincoln mercury dealer, gave them the keys to the vic, wont be able to look at it till tuesday but they gave me this caddilac to drive. caddilac clitara, something or another. nice little dealydoo, kinda like a normal compact-midsize car except right wheel drive.Last edited by DanHool; 07-20-2006, 12:12 PM.
