03 LX Sport with no park/running lights
    I just noticed when moving the Vic tonight that I have no park/running lights/rear plate lights. Headlights work fine, as do the brights. Dash lights up like normal. All I have is headlights. Brake lights work when pedal is pressed and the chime dings when I turn the headlight switch to park mode as to indicate the lights are on. Is this another LCM failure?
    Could be as faulty LCM's do some strange things!
      try fastblackmerc. He ma be able to help you. Also there may be some writeups here about replacing the relays which go bad in the LCM
        Here's a link to the write up on CVN: https://www.crownvic.net/ubbthreads/...Number=1437302
        Here's the pic of the relay layout:
Name:	2003 LCM relays.png
          Thanks guys. Appreciate the pic from Sly. Now that I see that, it's the same pic that I used when I replaced the headlight relay on it many moons ago and hasn't shown any issues until now. I checked fuse 21 tonight and it was good. I gave the LCM a few good smacks while I was under there are low and behold all my parking lights came back up. I left them on and jiggled the wire harness and smacked the LCM quite a bit to see if I could get them to shut off again but so far they're still working.
          Spoke with Chris at ADTR and he still has rebuilt LCM's for sale for these years. Might just be worth the money to have an updated one and move on. I have zero time to mess with this right now and I can't afford to have it go into "dark mode" randomly.
            If the LCM seller does not want the old one back, I would suggest keeping the core and marking it as core. Just in case you need to buy another LCM from someone else.
              Great idea but I think if he gets one from ADTR they will want his for a core (unless he wants to forfeit the core charge which may be up to $150)!
