Last night I hear a ticking when the thermostat temperature is below ambient. It sounds like it's coming directly from where the blend door actuator sits. It seems to be working for the moment.
Over the past 4 years I've almost completely overhauled the HVAC system. Is it normal to have to replace the blend door actuator every 2 years?
When I installed the new one, before reassembling the dash, I monitored the blend door actuator in action. I noticed that when the thermostat was set to 65 the blend door appeared closed. When setting to 60, the next lowest value, It looked like the actuator was putting more pressure on the blend door but not necessarily closing it more.
Am I using the HVAC wrong? The failed actuator had striped teeth off the gears. Before I was setting the temperature at a reasonable setting somewhere around 70 or so. After replacing I thought maybe if I used more extreme settings it wouldn't be constantly wiggling back and forth and wear out the gears. Perhapse it is the most extreme setting that are putting varying pressure on a single tooth. In the winter I would ajust the temperature so that the blend door was fully open. Run the blower on the lowest setting. And open the window if it gets too hot. That's probably what melted the blower motor resistor. The blend door actuator probably was cooking up there too.
Should I try to get a new actuator from the dealer? Should I get another cheap one from rock auto or perhapse try the auto parts stores? Do you think I would be ok if I operate it in the middle? That's the way I assume it is intended to be used. I'm considering modifying one bypassing the servo. Operate it off a simple on off on Last night I hear a ticking when the thermostat temperature is below ambient. It sounds like it's coming directly from where the blend door actuator sits. It seems to be working for the moment.
Should I try to get a new actuator from the dealer? Should I get another cheap one from rock auto or perhapse try the auto parts stores? Do you think I would be ok if I operate it in the middle? That's the way I assume it is intended to be used. I'm considering modifying one bypassing the servo. Operate it off a simple on off on switch. Or drilling a hole in the dash in order to reach with my hand. Does anyone have any techniques for prolonging the life of the blend door Actuator?
I was so close to having air conditioning in my car for the first time ever. Darn!
