My friend's '96 CV has a digital dash. The fuel gauge either reads "CO" (circuit open) or "F". Nothing anymore in between. I don't think the issue is in the dash but rather a wiring short from the sender to the dash (and most likely near the fuel tank). Could be the sender itself but if I had to bet, I'd say a short. Thoughts?
Wonky Digital Fuel Gauge
Most likely the level sender in the tank. If a multimeter is handy, get under the car and pull the wiring connector off the fuel pump assembly and check the resistance of the level sender. Not sure which two wires that is, but if the harness has two fat wires and two skinny wires, go for where the two skinny ones connect. That will be the level sender. If you get more than 200 ohms, the sender is bad or the connections are crap. The range should be less than 200. Somewhere between 20 and 160 from what I can find. If you get a reading near the range, try cleaning the connector with some contact cleaner. Otherwise, probably going to have to replace the assembly. While you're under there, you can check the wires for damage.
Broken or loose wire is a real possibility. A lack of continuity (broken connection) would be a form of short? I was told, the tank had been changed along with a new Motorcraft Fuel Pump/Sender some years ago so who knows how the mechanic went about his business?What I Own: 1993 Mercury Grand Marquis GS
Thanks for the detailed explanation and most helpful video! I would agree the issue is in the wiring as opposed to a problem in the digital dash (more expensive but easier to get to - at least for me!).What I Own: 1993 Mercury Grand Marquis GS
The usual culprit is a crusty connection at the fuel tank connector, which is why I said to check that first. It's also fairly easy to get to (other than the crawling under the car part).
Originally posted by sly View PostThe usual culprit is a crusty connection at the fuel tank connector, which is why I said to check that first. It's also fairly easy to get to (other than the crawling under the car part).What I Own: 1993 Mercury Grand Marquis GS
I'm going with bum sender. Its a wiper on a resistance track that is printed on a circuit board. Fair bet the board is cracked and unless the float is full up its hitting the dead part of the board.
the sending unit is on the front side of the tank directly above the diff cover.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostI'm going with bum sender. Its a wiper on a resistance track that is printed on a circuit board. Fair bet the board is cracked and unless the float is full up its hitting the dead part of the board.
the sending unit is on the front side of the tank directly above the diff cover.What I Own: 1993 Mercury Grand Marquis GS
Originally posted by massacre View PostIf it's the same as a 93, yes there is a 4-prong plug that plugs onto the sending unit.
[ATTACH=CONFIG]57439[/ATTACH]What I Own: 1993 Mercury Grand Marquis GS
It's a 4-pin connector either way. Also, keep in mind the fat vs skinny wires to figure out which ones to test.
I'm leaning towards bum sender myself. I have a spare one from my old fuel pump assembly for my 93 just in case the "new" sender dies. I had to replace mine due to the pump giving up. Just make sure to run the tank down to about a quarter tank and then changing that pump/sender assembly is about a 30 minute job. Hour if it's stubborn.
