So what is the factory amp output, and anyone know a good place to good a retrofit high output alternator.
AlternAtor question
It should be 130 amps for your car, uh you could re do it to use the new 200 amp one, but I do not see a need to do so, unless you have a 40 amp lightbar, and about 3 motorola radios? 130 is higher than most cars ever were in the 80's-early 90's. 130 will push a really decent stereo amp system, if thats what you are after, add a capacitor or 2.
I thought only 95+ had the 135a stock alt to run the fan. If not, go to the bone yard and find the alt out of a 95-97 panther and take the power wire too cause it should be thicker. Im not sure but I don't think you have a 130a alt. One of those in good shape will be more than enough for most all your needs.Chris - A 20th Century Man \m/ ^.^ \m/
