Originally posted by 87GrandMarq
View Post
Spark plug O-rings
It's a 98. 101k miles.
It's not that the plug is drenched in oil, just slightly on the threads, and dark(carbonization?) on the spark tab.
I ordered the coils on AMZ, all 8 of them, last night and they're on their way already. Under 30 bucks the set.
Asked once at Advance Auto Parts and the guy told me something like 38 bucks per piece!
Originally posted by LibertyAddict View PostWhat's the difference?
Also, not sure what year the problematic all plastic intake manifold started, but the failure of the coolant crossover on my 2000 MGM was nothing more than a teardrop leak on the front passenger side that I happened to notice when it was warmed up. Enough coolant had accumulated in a spark plug well to cause problems.Last edited by IPreferDIY; 05-21-2019, 12:44 PM.
The actual coil is inside the plastic case. The idea is similar to a transformer with a whole bunch of wire wound around stuff. The spring thing inside the rubber boot is just a conductor to get the juice from the coil to the plug.
That's the positive crankcase ventilation (PCV) valve. They're fairly cheap and easy to replace. I guess it's telling you it's time. I would recommend only a Motorcraft replacement.
Originally posted by IPreferDIY View PostAlso, not sure what year the problematic all plastic intake manifold started, but the failure of the coolant crossover on my 2000 MGM was nothing more than a teardrop leak on the front passenger side that I happened to notice when it was warmed up. Enough coolant had accumulated in a spark plug well to cause problems.
Actually, one of my first posts here, if not the first, was about that.
The IM cracked on me and the mechanic and I changed it in a couple of hours. All went well, no more coolant leaks, flushed the system and put new juice in, but I must say I noticed a slight rocking after that fix. Which I thought it was air on the coolant system, so I thought no biggie, and I let things be. That very rocking, shaking, got worse with time, and from what I've gathered here I suspect some coolant got into the coils and messed them up, and with time they deteriorated to the point my car now has Parkinson's.
I tried something else and I noticed a decrease of RPMs.
When on Parking, all fine, but when I shift to Drive the RPMs drop noticeably, then when I go back to Parking I get a sudden acceleration that lasts a second and the RPMs go back to normal.
Also, the rocking seems to happen the most when in Drive.
Originally posted by LibertyAddict View PostAre there more than one PCV valve?
I get varied results.
[ATTACH=CONFIG]52055[/ATTACH]
If the PCV valve has never been changed, it's definitely due. They should be changed regularly on these cars even if they pass the rattle test (i.e. hearing the inner part move around when you shake it). Try changing it and see what happens. I remember when I changed mine, the engine did a lot better with finding its proper idle after a cold start.
Did you actually see coolant in any spark plug wells when you changed the IM? That could certainly cause problems.
Another possible issue might be the idle air control (IAC) valve. It feeds enough air for a proper idle, and it can get gummed up or die outright. Sometimes people describe having to keep their foot on the gas to keep the engine running while in gear. Replacing that is more expensive, so try the PCV valve first.Last edited by IPreferDIY; 05-21-2019, 04:41 PM.
Can't tell if the intake has been replaced or not. If it does not have the metal coolant crossover (hose goes into the thermostat housing and the crossover from that point to the other side is metal) but instead it's plastic, you need to replace the intake. If it has been replaced... check the torque on the bolts that hold it down. Should be 15-22 foot pounds. The one on my wife's 2000 Crown Vic was actually loose. Tightened it all to spec and it ran great again. Page 14 of the following PDF shows the pattern to tighten the bolts. If any of those are loose, it'll cause problems. If the intake is cracked... it'll cause problems. If the coolant crossover is plastic, it'll cause problems.
http://www.grandmarq.net/sly/2001%20...20Manifold.pdf
Originally posted by sly View PostCan't tell if the intake has been replaced or not. If it does not have the metal coolant crossover (hose goes into the thermostat housing and the crossover from that point to the other side is metal) but instead it's plastic, you need to replace the intake. If it has been replaced... check the torque on the bolts that hold it down. Should be 15-22 foot pounds. The one on my wife's 2000 Crown Vic was actually loose. Tightened it all to spec and it ran great again. Page 14 of the following PDF shows the pattern to tighten the bolts. If any of those are loose, it'll cause problems. If the intake is cracked... it'll cause problems. If the coolant crossover is plastic, it'll cause problems.
