MAJOR PROBLEM!!!!!!
    MAJOR PROBLEM!!!!!!
    I ve been driving my car recently for the first time 3 days in a row i went 50 miles around town..... AIt eat two quaters of a tank
    Have you checked for fuel leaks?
      just replaced the fuel line i dont see any hittin the ground
        so are yous saying it eats a half tank???
        tom had a problem like that with his merk
        so we fixed it with a 4 barrel edelcrock
        dont think that will help anything but ya know!!
        Sellin off toys... need money for the dodge!
          IT helped me!
            oh you mangs and your carberation........theres something wrong mang.......hard to splain on teh intraweb...........or you full throttle the whole time......need to check all the shit under the hood.......cablemangs 85 vic runs like a raped ape and is stil all stock and gets good mileage...........as pete sais cfi is goodness.......believe me it not that bad when you get all the graemilins out
              ya my merc eats gas fast to unless i drive it like an old man , which i have to do sometimes just to save gas...
                My suggestion is not to read too much into half tank readings. My car almost always eats through the first 1/2 tank of gas in 80-90 miles, then takes 150-160 to finish the other half. If you think it's sucking gas really fast, go through a ENTIRE tank and make sure. Sounds like you have already checked for leaks. BUT and FYI tip, when you turn your car on (before starting it, just in the on position) the fuel pump gets primed. So turn your key to the off-run-off-run-off-run position several times, then check for leaks. Do this on a cold engine as well, so that if something is leaking on the engine it doesn't evaporate away before you see it.
                  i wanna do 4bbl conversion soon i need stuff it anyone can get it for cheap reall cheap
                    My car is exactly the opposite of Blaze's. 160 miles to a half tank, maybe 260 and its at 1/8. Calculate your actual fuel economy before getting too worried about it.
                      Since my thermostat took a dump my 100 or more miles to the firstr 1/4 tank is more like 140 to the half mark. Thats at 180* at 160* it was worse.
                        do a full tune up and replace the T/stat. check for stored trouble codes if possible.
                        vaccum leaks will also kill fuel mileage.
                          It was doing good 23 to 24 MPG after replacing the thermostat a few weeks ago ran at 195. Then it blew the bypass hose over heated a bit. replaced hose and started running at 190. Friday the 13th blew the front heater return hose. Replaced that and it started running at 180. Now the economy is down to around 17.
                          Figure overheating it toasted the new thermostat. Heater output is down so looks like I have to go in there again. If that dosent get my economy back to before over heating will have to pull the air and water temp sensors and check there output with the multi meeter to see if there with in perfered range not just allowed range. I have found that to be important. I have even tested them at the store you wouldnt believe how many are not in the perfered range but are in speck. I have pulled used ones that are better than new ones.
                            my comments were directed to the 83countrysquire about his "major problem"
