The 40s were designed off the old 351s the exhaust was standard old 302 stuff from the late 60s the exhaust was designed off the 260 and 289 HI PO. If you research it many of the older heads flowed better than the newer stuff. 240 6s FLOWED BETTER THAN 300S. The cobra jet 428 were actually old 390 HiPo stuff with a different combustion chamber and chromed valve stems. The Clevland heads were a design from the BBC. The older 170s had the best air flow.
I used Ideas softwere. Designed engines for Ford for 16 years. For about 8 of those years it was fun then something happened. A lot of my friends retired early for that reason.
