Small Block Ford block off kit?
    Does anybody make a block off kit for the small block Ford EFI engines? I need to cover the intake, exhaust ports or header collector, and whatever other orifice that I failed to mention from critters while I get parts for an engine. I could probably make them myself out of some thin steel using the gaskets for a template, but if someone already makes them, that would save some time.
    We have one, but for a carb motor.
    you can just use tape, but i believe summit sells the kits, i dont think anyone makes one that will cover the EFI part of it though.
      get some alluminum tape, critters dont like to chew through it, thats what i use while my car is stored. never had any problems yet (knock on wood)
        Thanks for the tip. I was going to use duct tape on top of some home made plates but the rodents might acquire a taste for the tape. I was thinking that I am going to buy a lift plate for the EFI and just leave that on there until the time comes to do the swap.
          Thats what I used but the aluminum tape seems better for the long run!
