whats the price of 2 core radiator?
    how much is a two core radiator? and can you get one from advance I need one asap mine is leaking badly near the tranny cooler line I guess thats what I get for getting a 35 dollar used radiator at crazy rays any info well help thanks mangs
    Got to Courtney's Radiator in Mt.Airy. It's in the back of the cozy corner restauraunt right by Jimmie Cone. Good prices and great warranty if anything does happen-Which I've only had happen once, a pinhole leak in the 4 core rad of our Bronco.
    I'd get the 2 row aluminum one if you can. It's not too expensive. None should be over 140 bucks.
      thanks mike I will check them out for sure thats what I 've got now a pine hole leak near the radiator cooler line I've tried to seal it with rtv sealent but its not helping.
        The RTV won't hold up to the pressure. a good cleaning and some epoxy probably would hold for a bit. Maybe even crazy glue...
          i got monty one for around 110 bucks at advance with my discount
          toms 3 core was 160 at advance........reg store price is 198
            Cheapest I found online is 105.
            '95 Ford Bronco XL -
            sigpic :rebel:
