Hey guys, recently I bought an 89’ Grand Marquis. When I went to do an oil change I found that someone previously stripped either the plug or the pan on the rear sump, and put one of those rubber expandable plugs in :/. I did notice that there were some threads still in the pan so I went and bought a 1/2 - 20 drain plug to see if I could get lucky. The plug starts to thread about maybe 2 full turns then starts to get some resistance. I think I can run a thread chaser through the pan and fix my issue.
My question is what size drain plug is on the 89 panther 302s? I was doing some reading on the forum and someone said that 1989 is the only year with a metric drain plug. Is this true? I don’t want to use the wrong size tap if that’s the case.
Thanks.
Thanks.
