WTF? 91 5.0 misfire still?????
    I have a 91 merc with an anoying misfire when the car gets warm...its high mileage and not sure what this could be...seems to change with engine temp and the weather....anyone got any ideas?
    car had a complete tune up in october past and the module on the distribute replaced last weekend.(module was a huge improvement but still has a bit of a mis at times)
    How long has it been since the ignition system was overhauled?
      Coil and associated wiring? Also check the big connectors on the intake that are for the engine harness.... Those cause all kinds of issues.
      Maybe you have my old car. i got fed up with it and traded it in... Poor milage and a mysterious miss...
        which ones are they cause i pulled a huge mouse nest out of under the plenum. bought this car from a friend who never had any problems till he parked it for a few months....was thinking about the coil myself too
          the mouses might have chewed into some wiring.....this is common
            Bingo! A buddy of mine's Mustang had a mouse nest underneath the intake, and it ate some of the injector wiring. It also then started with a funky miss............... Then it melted a valve on Nitrous.
            Found the eaten wiring AFTERWARDS.................
              Probably won't help, but have you pulled the codes by any chance?
                mouses?
                Nick
                88 Colony Park LS
                  Could be a bad injector if the wiring is ok.
                  You could use your timing light and go form cylinder to cylinder to see if it is spark related. If that is OK, then you could pull 1 plug wire at a time until you see wich cylinder is missing.
                    problem is intermitting.....???? ran like a dream today but yesterday was a bag of shit
                    also seems to act worst between 50 and 70 kms/hr
                      I wonder if maybe the temperature sensor isn't going funny. If the coolant temp sensor is bad, it messes up the fuel mix calculations and the EGR operation. Just a thought. Codes might tell you something useful, or you might need to meter it out to verify its in range. The chart matching temperature to resistance can be found here:
                      http://fordfuelinjection.com/index.php?p=28
                        The BIG connectors... The biggest ones on the car...Back of the intake Behind the EGR spacer.
