Does this sound like a stock HO cam?
    I'm thinking it doesn't, as it sounds more "lumpy" than my '87 GT sounded........... And it's coming through much more restrictive exhaust ('87 had E/L headers and an off-road H-pipe, Lincoln has factory 4-cats and factory style duals).
    Let me know what you think guys.............
    Oh, and you may need to give the volume to her a bit to really hear it...........
    https://www.darkfibrecommunications....s/Lincoln2.wmv
    This is my "mystery" cam that came from that HO motor that my heads came from........... Pulls 15" of vacuum............
    1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
    hmm sounds "stock" to me....That car is pretty quiet..
      Sounds a little meaty to me.
        Turn your speakers up, it's not the car that was quiet, it was the recording.
          ok
            E-cam
            LTD is still here
              Originally posted by 1987LTDmasta View Post
              E-cam
              That's kinda what I'm thinking it is................
                oooh..if that's the E cam, I can't wait to get mine in
                little bit of a lope, but not too much! very kool.
                  If that's the case then you are going to need a tune to get it to run well.
                    Exactly, or convert the car to MAF like I did. It was PIG RICH at idle when it was Speed Density.
                      yep.
                      i believe speed density requires 12" of vacuum at idle.
                      LTD is still here
                        yep.
                        Oh, I think it's more than that (at least to not run rich). This one pulls 15", my stock HO cam in my stang used to pull ~19" and that's what the stock cam in the TC used to pull too, around 20"............
                          Even with a MAF, you will need a tune. It'll run as it is now, but to get those 16 second passes you are going to need a tune.
                            To get the absolute MOST out of it? Yes, you are correct. But, to pass an e-test and run decently (which it is doing right now) it's OK the way it is. The reason I converted to MAF was so that it would pass an E-test, which I knew wasn't happening when it was SD.
                            With a tune, I'm sure there is more power there, but it does run well (and needs a Mustang shift governor) the way she sits.
                              Yes, definitely not a stock HO cam, they don't have that distinct lope yours has.
                              Nick
                              88 Colony Park LS
