i posted in another thread, but though I might be able to get some opinions here.
I acquired an 82 marq, which was stripped out and the guy was going to demo derby it. I saved it from the crusher and turned it into a 3/8 mile dirt circle track car. 302 engine. It is the entry level class, only thing is I have ten inch wide 18" diameter hoosier circle track wheels. It has 3.08 gears, and in the first race on saturday i had to run it in first to keep up with the pack. Some of the other cars are caprices, and 70's t birds. I tried to put it up in second and it wouldn't pull any, kept bogging down. My temp stayed around 180 degrees, so I wasn't even wrapping it out in first too much. Most other racers use second gear in they automatic trannies. What gear ratio would be best? also I was doing some research and these cars have an 8.8" rearend with 28 spline axles, which leads up to another question. Will a mustang 8.8" ring and pinion fit in my marq rearend, and also will my stock yoke mate up with the pinion gear for the mustang fine. I will get some pics of the car for you all to enjoy as well.
Thanks guys.
Thanks guys.
