tb gasket
    tb gasket
    well i bought a bored egr spacer and modified throttlebody off of lincolnmania a while back and i thought i had the right gasket size but apparently not. what are the differences in mm sizes throught the years?If they are different what year car do i tell them so i can get the correct gasket? does it even matter? all i told them was mustang 5.0 tb gasket and its not the right size.
    could someone also explain to me the best they can maybe with pictures on how to bypass the coolant from the spacer since scott recommended i do that on the bored spacer.
    Ask for gaskets for a 1988 Lincoln Mark VII. The Mark VII got the 60mm throttle body and egr spacer, the Panthers got a 50mm.
    Basically to bypass the cooler lines, all you need to do is hook them together. Use a coupler designed for 1/4" fuel hose and a pair of hose clamps.
