ok so i bought the f 150 that i talked about a couple weeks ago. i was going thru and doing all the plugs and wires looking hoping it was just a down plug or wire as i was changing all the stuff i was compression testing all the cylinders most of them came out around 120 ish but i had one as high as 150+ what is the compression supposed to be on those.
and it does have a bad valve in the #5 position my compression in that one is only like 55.
thanks
seb
thanks
seb
