The VV...
    The VV...
    I swear I cursed my self on this one. A few days ago I posted about my VV not giving me grief. Ahhhh yes. So I developed a small gas leak at the front (right where the line goes in). I had devloped this same problem on my '88, and was able to cure it with teflon tape. It never leaked again. So I decided to do the same on this car. By the way, the leak was from the big nut/ fitting that fits into the carb, not the fitting on the line itself.
    So I came home from school and decided I'd do this today. The engine was at operating temp, and I didn't feel like waiting, so i readied the hose and fire extinguisher. Call me stupid, because I have done smarter things.
    I cracked the line from the fitting, and it sprayed a little gas (I assume some spray is usual as this happened when I changed the filter). When I freed the line from the fitting, the line weeped constantly. It never stopped the whole time I removed the other fitting and taped it up and reinstalled it. (If there wasn't a quart of gas laying in the hot intake, then there wasn't an ounce; don't worry, I thoroughly diluted it, and now I have a very clean intake) .
    Is it supposed to leak like that the whole time? I figured it would leak until the pressure was released, presumably a few seconds, and then stop. Is this normal? Did it have something to do with the fact that the car was hot? Any thoughts on this would be appreciated.
    hehee....
    Yeah, that's fine, residual pressure and the higher temp will do that.
      Originally posted by mrltd View Post
      hehee....
      I should have never posted that stuff about the VV not giving me any grief. I cut my own balls off.
        That's not really a VV specific problem, that's a carb problem in general.
          Still not as bad as me telling the passenger how reliable and great my car is, only to have it stall out seconds later and never race that day.
            And people wonder why I refer to my car as a bitchy money hungry POS.
