those explorer cams are a beast for low end. neck snapping low end torque
Does it have to be from a 97 or are the others different?
Repeat after me.... ALL 302s and 351s except for the Lightning from 1994 on use the exact, very very same, identical, F4TE-BA camshaft. .264/.280 lift @ cam 256/266 advertised duration.
